Hi all,
I'm trying to run a stepper motor with the accelStepper library in arduino ide, a TMC2209 drive and an Adafruit Grand central M4 (samd51).
For make this work, I need a Serial2 or Serial3, but I try what I find on the internet, but still NOT WORKING.
Did you have a example of arduino coding with a Serial2 or Serial3 working?
Serial2 and Serial3 for adafruit Grand central M4
- 4MInnovations
- dastels
Re: Serial2 and Serial3 for adafruit Grand central M4
Serial2 and Serial3 instances aren't defined in the Arduino board support for the Grand Central. However, the support for them appears to be there. I'm playing around with it to see if I can get them working.
The files in question are (on my machine):
~/.arduino15/packages/adafruit/hardware/samd/1.7.11/variants/grand_central_m4/variant.h
~/.arduino15/packages/adafruit/hardware/samd/1.7.11/variants/grand_central_m4/variant.cpp
- dastels
I got them working. I have no idea what impact enabling them will have on other SERCOM usage.
First make sure your board support is up to date.
In variant.h, near the end after the line extern Uart Serial1;
In variant.cpp, at the very end:
Serial2 is on pins 19 (Rx) and 18 (Tx).
Serial3 is on pins 17 (Rx) and 16 (Tx).
I tested both using a USB/serial converter (a CP2104 Friend in my case).
extern Uart Serial2;
extern Uart Serial3;
Uart Serial2( &SERCOM_SERIAL2, PIN_SERIAL2_RX, PIN_SERIAL2_TX, PAD_SERIAL2_RX, PAD_SERIAL2_TX ) ;
void SERCOM4_0_Handler()
Serial2.IrqHandler();
void SERCOM4_1_Handler()
void SERCOM4_2_Handler()
void SERCOM4_3_Handler()
Uart Serial3( &SERCOM_SERIAL3, PIN_SERIAL3_RX, PIN_SERIAL3_TX, PAD_SERIAL3_RX, PAD_SERIAL3_TX ) ;
void SERCOM1_0_Handler()
Serial3.IrqHandler();
void SERCOM1_1_Handler()
void SERCOM1_2_Handler()
void SERCOM1_3_Handler()
- 4MInnovations
Thank you,
I tried your modification and It's seam to work for me. :)
- 4MInnovations
Hi, I try your modifications and it seem to work, but I have a problem.
I try to use my grand central M4 to control 2 drives TMC2209 in UART (1-wire) and an 2 pins address (MS1 and MS2).
All the communication work with the default address 0, but I can't communicate with the 3 others address.
I try the exactly same setup and software with a arduino Mega, and all it's working.
The TMC2209 is 3.3V or 5V ready for the control and the uart.
I try many baud rate.
I try a 470 ohms resistors instead of the 1 kohms for passing the uart-1 wire to two wires.
Do you have any idea?
- dastels
Hard to say, as the AtMega MCU of the Arduino Mega and the SAMD51 of the GrandCentral are completely different.
Are you powering the TMC2209 with 3.3v from the GrandCentral?
- 4MInnovations
Hi Dave,
yes, my Vmotor is 24V for the both setup.
My Vio is 5V from the Mega and 3.3V from the grand central.
- dastels
You say you're splitting one UART signal into 2? That's not something I'd do. But.. because you're running at 3.3v rather than 5v changes things. How? I'm not sure, but it probably does.
- 4MInnovations
Hi Dave,
this is the uart:
this is the uart:
- dastels
I've never seen that done, nor can I think of why (other than the software needing the output echoed and the device not doing that. I'm curious.
