Please help,
I'm new to the Circuit Playground Express. I want to make a permanent enclosure (Box Light) for my circuit playground. Currently I have the Forever block with the show animation block in it. But if I disconnect it from the computer and reconnect it show the default green and I have press the reset button to start the animation code. It I permanent enclose my box I can't access the reset button.
Is there a block code sequence that starts the light animation automatically??
Thanks in advance.
How to create a block code for the Circuit Playground to start the code without needing to hit the reset button
- surfNcrypto
- adafruit_support_carter
Re: How to create a block code for the Circuit Playground to start the code without needing to hit the reset button
Are you programming the CPX using Makecode?
