Is it possible to interface a regular LOLIN32 esp32 Devkit Board with the 2.9 E-Ink FeatherWing display module.
I have figured out to the mapping of the devkit, but I wasn't able to find any detailed pinouts on the 2.9" E-ink Feather Wing Display. And I was also not able to find its library's name as there were multiple 2.9" b/w libraries in the GxEPD library
2.9 E-Ink FeatherWing Compatibility
- adafruit_support_carter
Re: 2.9 E-Ink FeatherWing Compatibility
Using FeatherWings on non-Feather boards is not supported. It may be possible, but will require you to figure out the pin specifics.
Schematics are available here:
https://learn.adafruit.com/adafruit-2-9 ... /downloads
As well as links to the PCB files.
