Hi
I'm searching for a solution to save a variable and have access after repower the device. Is this possible?
The Eprom solution seems not the best... So I search for another solution.
I found this guide: https://learn.adafruit.com/cpu-temperat ... filesystem
But I still don't know If I can read the saved values.
Can someone help?
Many thanks in advance
Michael
Save variable to file
- millercommamatt
Re: Save variable to file
What device?
How much data and what format?
What have you already tried and what about that didn't suit your needs?
- sj_remington
What MCU and programming language are you using?
If the MCU has EEPROM, that is very convenient, very reliable and easy to use with the Arduino IDE.
- blakebr
SJ,
If the problem with EEPROM is speed or the 10,000 or 100,000 read/write limit, check out the FRAM storage chips. No delay while waiting for write and 10,000,000,000 read/write cycles. I have one under test and after 2,325,000 read/write cycles, no problems.
Bruce
Bruce
- mbinno
to all, thanks a lot
I'm using the Adafruit ESP32-S2 Reverse TFT Feather with circuitpython.
I already try to save some text according to the linked guide to a file on the Feather drive. But it doesn't work...Not sure, but I think the guide seems to be pretty old... And of course, I'm not a code monster :-)
Regarding the data, I have only store one int value, but a high number of times (around 1'000'000 times, every 0.5s to 1s). That's the reason why I believe that the Eprom solution will not work, at least not for this high number of cycles.
Yes,the FRAM storage chips could work for me. But this means, I need to attach a additional device. If it's possible to save the int value on the existing feather, I definitely prefer this.
- mbinno
Regarding the save to file solution, I try this:
boot.py:
import board
import digitalio
import storage
switch = digitalio.DigitalInOut(board.D13)
switch.direction = digitalio.Direction.INPUT
switch.pull = digitalio.Pull.UP
# If the D13 is connected to ground with a wire
# CircuitPython can write to the drive
storage.remount("/", switch.value)
code.py:
import time
import board
import digitalio
import storage
led = digitalio.DigitalInOut(board.LED)
led.switch_to_output()
var_test = 0
while True:
var_test = var_test + 1
str_var_test = str(var_test)
time.sleep(0.5)
print(var_test)
try:
print("in try")
with open("var_test.txt", "a") as fp:
while True:
fp.write(str_var_test)
fp.write("\n")
print("write to file")
time.sleep(0.5)
except OSError as e:
print("os error")
delay = 0.5
if e.args[0] == 28:
delay = 0.25
else:
pass
I'm able to allow circuitpython with the D13 pin to save to the drive. This should work. It also creates a text file var_test.txt but it remains empty.
boot.py:
import board
import digitalio
import storage
code.py:
import time
import board
import digitalio
import storage
var_test = 0
while True:
time.sleep(0.5)
print(var_test)
try:
print("in try")
while True:
fp.write("\n")
time.sleep(0.5)
print("os error")
delay = 0.5
if e.args[0] == 28:
delay = 0.25
else:
pass
- blakebr
mbinno,
The EEPROM, Flash memory on the PCB and MCU Flash memory all have write thresholds less tan the one million writes you want to do.
Bruce
I would suggest a test run to see how long the above three long term memory types last. Also I don't think any MCU can manage one million writes in less than one second. But I could be wrong, ask my wife. ;-)Regarding the data, I have only store one int value, but a high number of times (around 1'000'000 times, every 0.5s to 1s). That's the reason why I believe that the Eprom solution will not work, at least not for this high number of cycles.
Bruce
- mbinno
@ Bruce I ordered two FRAM memories for testing. It's not planned to save 1'000'000 writes in less than one second. It's planned to save around 1'000'000 writes every 1s. ;-)
Is it possible to save a integer with his max. length directly to the FRAM? I can't find anything in the documentation...
- blakebr
mbinno,
The FRAM library only saves bytes. I had to implement a 4 byte number storage function in CircuitPython. This lets me go to 2_147_483_648 before it rolls over. I am sure the Admins here have a more elegant way.
Bruce
Bruce
int_size = 4 # Bytes
Loops = 0x98+0x00 # 152/0x98 # FRAM memory locations
Starts = 0x98+0x04 # 156/0x9c # FRAM 4 bytes per intiger number
this_run = 0x98+0x08 # 160/0xa0 #
next_num_0c = 0x98+0x0c # 164/0xa4 #
next_num_10 = 0x98+0x10 # 168/0xa8 #
GROVE_4 = (board.GP7, board.GP6) # My I2C port
FRAM50 = adafruit_fram.FRAM_I2C(GROVE_4], write_protect=False, wp_pin=None)#, address=0x50)
def read_FRAM(adr): # 4 Byte Intiger
#print(adr)
if(adr % int_size): return(None)
num = 0
for i in range(int_size):
b = 3 - i
num *= 0x100
num += (FRAM50[b+adr][0])
#print(i, FRAM50[b+adr][0])
return(num)
def write_FRAM(adr, val): # 4 Byte Intiger
#print(adr,val)
num = val & 0xFF
#print(i, num)
FRAM50[i+adr] = num
val = int(val/0x100)
return(num)
def inc_FRAM(adr):
val = read_FRAM(adr)
val += 1
return(read_FRAM(adr))
