Hello
I recently bought a Teensy 4.1 and I received it on March 14th (order number is: #3035183-6285724507)
I soldered the pins onto the board and when I plugged the board into my compute the teensy ran its led blink program like what it should be doing. I followed the instructions on PJRC's website and I downloaded Teensyduino. When I tried to upload a new program to the board, I pressed the program button and a red led blinked with no board showing up in Arduino IDE or the teensy program.
I tried 4 different USB cables and ports on my computer and nothing worked.
I also mode sure all the components were on the board and that there were no bridged pins.
If this is not fixable, is it possible to exchange it for a new one?
Thanks a lot!
-Dominic
Teensy 4.1 red light blinking
- techkid9724
- IMG_0371.jpg (65.08 KiB) Viewed 1102 times
- Screenshot 2023-03-16 210852.png (42.14 KiB) Viewed 1102 times
- Screenshot 2023-03-16 210820.png (14.58 KiB) Viewed 1102 times
- Franklin97355
Re: Teensy 4.1 red light blinking
Are you sure the cable has data pins and is not just a 'charging' cable
- techkid9724
I think that was the problem, thank you so much for replying, I just bought micro USB Data cables.
Thanks a lot!
-Dominic
Thanks a lot!
-Dominic
