eTape sensor damaged?
andyshinn
Post by andyshinn »
I am building a project using the 12" eTape. I am currently bench testing it using a ESP32-S2 Feather, OLED scree, and relay wing. I have wired it to pin T8 of the ESP32-S2 using the included 560Ohm resistor as a divider.
Any little movement of the tape, even me just pushing on the wires a bit, makes the values jump around. See video example at https://www.youtube.com/watch?v=HTOZO6uWa9g.
I attached the schematic and layout I have attached the sensor. Below is the configuration I am using in ESPHome:
external_components:
  - source:
      type: local
      path: esphome-components/components
wifi:
  ssid: MySSID
  password: !secret wifi_password
ota:
esphome:
  comment: Bucket
  on_boot:
    priority: 600
    then:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
          brightness: 50%
          color_mode: RGB
      - script.execute: screen_timeout
web_server:
  port: 80
esp32:
  board: featheresp32-s2
i2c:
  sda: SDA
  scl: SCL
substitutions:
  relay_pin: T10
  button_a_pin: T9
  button_b_pin: GPIO6
  button_c_pin: T5
  status_led_pin: T13
  status_pixel_pin: GPIO33
  etape_pin: T8
status_led:
  pin:
    number: $status_led_pin
    inverted: false
output:
  - platform: gpio
    pin: $relay_pin
switch:
  - platform: output
    output: relay_output
    on_turn_on:
      then:
        - light.turn_on:
            red: 0%
            green: 100%
            blue: 0%
            color_mode: RGB
            effect: "Strobe"
    on_turn_off:
      then:
        - light.turn_on:
            red: 0%
            green: 100%
            blue: 0%
            color_mode: RGB
            effect: "None"
  - platform: template
    name: "Keep Screen On"
    optimistic: true
    restore_state: true
    on_turn_on:
      then:
        - lambda: |-
            id(oled).turn_on();
    on_turn_off:
      then:
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812
    pin: $status_pixel_pin
    num_leds: 1
    effects:
      - strobe:
          colors:
            - brightness: 50%
              red: 50%
              green: 0%
              blue: 50%
              duration: 500ms
            - brightness: 0%
              red: 50%
              green: 0%
              blue: 50%
              duration: 250ms
font:
  - file:
      type: gfonts
      family: Roboto
  - file: "fonts/tahoma.ttf"
display:
  - platform: sh1107_i2c
    model: "SH1107 64X128"
    address: 0x3C
    rotation: 90
    lambda: |-
      it.printf(0, 0, id(tahoma), TextAlign::TOP_LEFT, "Level: %.0f%%", id(etape_level).state);
      it.printf(0, 20, id(tahoma), TextAlign::TOP_LEFT, "Res: %f", id(etape_resistance).state);
      it.printf(0, 40, id(tahoma), TextAlign::TOP_LEFT, "Pump: %s", id(relay_switch).state ? "On" : "Off");
binary_sensor:
  - platform: gpio
    pin:
      number: $button_b_pin
      inverted: true
      mode:
        input: true
        pullup: true
    on_press:
      then:
        - lambda: |-
            id(oled).turn_on();
  - platform: gpio
    pin:
      number: $button_a_pin
      inverted: true
      mode:
        input: true
        pullup: true
    on_press:
      then:
        - switch.toggle: relay_switch
script:
  - id: screen_timeout
    mode: restart
    then:
      - if:
          condition:
            switch.is_off: keep_screen_on_switch
          then:
            - delay: 10s
            - lambda: |-
                id(oled).turn_off();
sensor:
  - platform: resistance
    sensor: etape_source
    configuration: DOWNSTREAM
    resistor: 560Ohm
  - platform: adc
    pin: $etape_pin
    update_interval: 1s
    attenuation: auto
    lambda: |-
      const float etape_min = 1850.0;
      const float etape_max = 400.0;
      const float etape_range = etape_max - etape_min;
      const float etape_percent = (id(etape_resistance).state - etape_min) / etape_range;
      if (etape_percent > 1.0) return 100.0;
      if (etape_percent < 0.0) return 0.0;
      return etape_percent * 100.0;
    unit_of_measurement: "%"
    accuracy_decimals: 1
    update_interval: 1s
logger:
  level: DEBUG
I am using the custom OLED component from https://github.com/jenscski/esphome-components
Is this normal or is the sensor damaged?
mikeysklar
Re: eTape sensor damaged?
Post by mikeysklar »
These are quite sensitive which is typical of sensors going through an ADC. Normally you would want to buffer values and average them out. eg. Read 100 samples and take an average rather than print every value change.
Which model of eTape (Ada product ID#) do you have?
andyshinn
Post by andyshinn »
mikeysklar wrote: Sat Mar 18, 2023 7:44 pm These are quite sensitive which is typical of sensors going through an ADC. Normally you would want to buffer values and average them out. eg. Read 100 samples and take an average rather than print every value change.
It is https://www.adafruit.com/product/464
mikeysklar
Thank you for the product link.
Were you able to start averaging values as the thermistor guide suggests?
andyshinn
Post by andyshinn »
I tried doing some averaging, but the values really don’t ever change in some cases. I got some PVC pipe to put the sensor in. Here’s another video where the sensor is about a street is I can get it and it isn’t moving yet it’s still just reads 100% even when I move it up and down.
https://youtube.com/shorts/9pAKyODWYX8
mikeysklar
Thank you for the video.
Since the sensor continues to read high there could be an issue with how you have connected the sensor to the ADC.
While I can see you are using a Feather tripler setup I cannot verify the wiring / resistor (560ohm) to the ADC pin. Can you describe or show that? Can you post the code you are running in code tags?
