PCF8523 Stemma/QT doesn't work with Feather ESP32 v2 out of the box
emmby
Post by emmby »
I'm trying to get the PCF8523 working. I've got a pretty simple setup:
Code:
  • Adafruit RTClib example for PCF8523, Examples->RTClib->pcf8523
  • Adafruit v2.1.1 fork of RTClib
When I compile the example code and run it, the PCF8523 breakout powers up and the green LED turns on, but I just see "Couldn't find RTC" in the serial output. I've tried two different feathers, two different usb cables, two different computers. Just one PCF8523 though since I only have one, although I did try using the other QT connector on the board.
I suspect the problem may be related to the re-numbering of the I2C pins in the Feather ESP32 v2, but I don't know for sure. Where are the pins configured?
emmby
Re: PCF8523 Stemma/QT doesn't work with Feather ESP32 v2 out of the box
Post by emmby »
Actually, just seems to be a startup race condition.
I changed the example from:
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    Serial.flush();
    while (1) delay(10);
(what is that infinite while loop for, anyway?)
to
  bool begin;
  do {
    begin = rtc.begin();
    Serial.printf("RTC begin=%d\n",begin);
    Serial.flush();
    delay(10);
  } while(!begin);
and it now finds the RTC by the second iteration.
Are the examples hosted on github somewhere? I'd be happy to submit a PR if people think this change is valuable.
adafruit_support_carter
Yep, examples are hosted with the library:
https://github.com/adafruit/RTClib
Here's the PCF8523 example:
https://github.com/adafruit/RTClib/blob ... cf8523.ino
The infinite loop is to stop things if the PCF8523 does not initialize, i.e. the call to begin() fails. In general, begin() should only be called once. It's working with your looping call, but sort of a hack.
If it's a power on race condition, try adding a delay before that code block:
  delay(500);  // POR delay
    Serial.flush();
