Hi.
I am trying to wire a 3.2 Inch Touchscreen from Adafruit. It shows up as a white screen even after I checked the code multiple times. I am using an ESP32 and I am using the right pins. I doubled checked everything multiple times. I would appreciate if someone could help me figure this problem out.
Thanks in advance,
Soham Patel
3.2 Inch Touchscreen is white
- mikeysklar
Re: 3.2 Inch Touchscreen is white
Can you show a photo of your wiring and either link in or put in code tags the example code you are running.
