Order# 3034899-6628471201
Two boards and both don’t have the charge LED working with lipoly battery is plugged into JST port. Please advise.
Best,
Aleks
Charge LED not working
- dastels
Re: Charge LED not working
What boards?
- Aleksbaron
Feather V2, my order number is as mentioned.
- dastels
Where is your battery from? Have you verified the polarity?
- Aleksbaron
- dastels
Batteries from Amazon are a red flag usually. Triple check the polarity.
- Aleksbaron
I’ll await Adafruit’s input, thanks for your expertise.
- dastels
I do work with Adafruit on the forums.
Does the LED do anything if the battery is not connected while USB is?
- Aleksbaron
Yes, it flickers when plugged into the PC. Very quickly.
- dastels
OK, that's the charger "looking for" a battery. So at least the charger isn't completely broken.
- dastels
Not to belabor the point, but can you post a photo of the connector on your battery?
- Aleksbaron
- dastels
That's as it should be. I've requested more eyes on this.
So, you leave it powered by a battery to drain it and when you connect USB it doesn't start charging? Or it charges but the LED doesn't light? Although the charger status output and the LED seems to be working.
- Aleksbaron
I noticed on one board the KD23 chip looks cooked.
I had two batteries and verified that the second had polarity wrong.
The other board looks good with the KD23
- dastels
The chip not looking burnt/melted/damaged is no indication that there is no internal damage.
If you used the wrong polarity battery, it very likely could damage the charger in some way.
One comment I heard is that not only are there no standards to the polarity of the connector, sometimes red for + and black for ground isn't even adhered to.
