Fusion BrkOut 2470 Connections
hucker233
Post by hucker233 »
I ordered the fusion BrkOut board 2472 thinking it had a STEMMA connector.
Unfortunately for me I should have ordered the 4646 board that has the STEMMA connectors.
Can I just take a STEMMA jumper connector cable and solder the bare wires on one end to the pads and plug the JST into my FeatherS2 or is there something unique going on with STEMMA beyond getting the connections right. It looks like I can just solder these u and be good to go:
Green for SCL
White for SDA
Red for V+
Black for GND
dastels
Re: Fusion BrkOut 2470 Connections
Post by dastels »
The STEMMA-QT connectors simple replicate the I2C connections in a solderless plug-n-play format. You can wire to the appropriate pads. See https://learn.adafruit.com/introducing- ... ical-specs for specifics. Note that the FeatherS2 has a JST-SH STEMMA-QT connector, not the larger JST-PH STEMMA connectors as on the PyPortal.
hucker233
Post by hucker233 »
Thanks for your help, the board is working as expected via our hacked in STEMMA connector.
