I want to make something like a Sinilink USB Switch Module, or a powerbank that can be turned on and off by Adafruit IO control. The goal is to power on and off something that is powered through a USB A plug and can be controlled by an app using Wi-fi or Bluetooth LE. The thing I have in mind to use it for is an IKEA HALVKLART closet light which normally needs to be pressed to turn it on or off, so it’s difficult to put in a place that is hard to reach. The light itself defaults to being on when first plugged in or after a power outage.
Ideally I would like to do as minimal soldering as I can and would like to use STEMMA/STEMMA QT and/or Qwiic if possible.
I want to make something like a Sinilink USB Switch Module but Adafruit IO compatible
- CorbeauCat
Re: I want to make something like a Sinilink USB Switch Module but Adafruit IO compatible
Not knowing how much current the lamps use, it would probably be a good idea to use a power controller like the TB6612:
https://www.adafruit.com/product/2448
It can handle 1.2A per channel, and each output channel can control two on/off devices. Any microcontroller can generate the signals that control the outputs, so it will be easy to integrate with online control.
- CorbeauCat
So a separate relay would not be necessary then, right?
Also, this forum post I linked below is about hacking the type of light I just mentioned, but it gives a closer look into the innards of the light:
https://www.eevblog.com/forum/projects/ ... net-light/
Correct.CorbeauCat wrote: ↑Mon Mar 20, 2023 12:51 pm So a separate relay would not be necessary then, right?
Given that the lamps take 5VDC power, mosfets are much faster, better behaved, and longer lasting. The TB6612 is basically a set of power mosfets with some control logic, so it's convenient for this kind of power control.
- CorbeauCat
What would be a good microcontroller for this that can run on a powerbank for an hour or so at a time? I also wonder if instead of having it be plugged into the microcontroller, if it is better that the lamp be wired directly to a MOSFET, it seems to have two wires running down the cable to the USB A.
Any of them..CorbeauCat wrote: ↑Tue Mar 21, 2023 9:44 pm What would be a good microcontroller for this that can run on a powerbank for an hour or so at a time?
Even the ESP32 boards, which can use 300mA when their Wifi radios are active, can last a couple of hours on a battery.
For simple programming though, a board like the Feather 32u4 Basic or the Feather M0 Basic would be good choices:
https://www.adafruit.com/product/2771
https://www.adafruit.com/product/2772
Those both have a nominal operating current of 11mA, 3mA of which is the power LED. They're easy to work with and will run for days from even a moderately sized battery.
The microcontrollers can't handle enough current to light the lamps, so you'll need some kind of external hardware to manage the power to the lights. A mosfet could do it, but you'd be responsible for writing all the code to make that happen, and correcting any problems that come up over time.CorbeauCat wrote: ↑Tue Mar 21, 2023 9:44 pm I also wonder if instead of having it be plugged into the microcontroller, if it is better that the lamp be wired directly to a MOSFET,
The TB6612 isn't strictly necessary, but is convenient. It already has the power mosfets and control circuits to make the mosfets change cleanly when controlled by 3.3V signals.
