I'm using the NeoPXL8 library on an RP2040, and when the Adafruit_NeoPXL8 object is destructed, the PIO state machine is not properly stopped. I.E. pio_sm_set_enabled(... false) is not called, nor is pio_sm_unclaim(...) and pio_remove_program(...) called. Am I missing something here?
Marcus
NeoPXL8 Library on RP2040 does not stop state machine on destruction
- Blish
- mikeysklar
Re: NeoPXL8 Library on RP2040 does not stop state machine on destruction
This is the Arduino library Adafruit_NeoPXL8 not the CircuitPython one that you are using?
I do not see an issue open on this would you like to create one?
https://github.com/adafruit/Adafruit_NeoPXL8/issues
- Blish
Will do.
I will also create an issue for "instantiates a NeoPixel object which claims an unnecessary state machine"
- pburgess
Can confirm, it does not release all resources properly. Didn’t see a use case at the time, figured the light show would always be running…but if there’s a situation that calls for it, I’ll see about fixing that.
- Blish
NeoPixel issue:
https://github.com/adafruit/Adafruit_Ne ... issues/351
This is in reference to the locked thread located here:
viewtopic.php?t=199942
- Blish
- Blish
PR#11 created for Issue #10
- Blish
PR#352 created for Issue #351.
