Can't figure out how to use microcontroller.watchdog on MatrixPortal M4
ceb2120
Post by ceb2120 »
Hello! I've been trying to use the watchdog module using this documentation. I've tried multiple versions of the code and haven't been able to get it to function properly.
When I run the examples from the documentation including this example:
from microcontroller import watchdog as w
from watchdog import WatchDogMode
w.timeout=2.5 # Set a timeout of 2.5 seconds
w.mode = WatchDogMode.RAISE
w.feed()
or this example:
import microcontroller
import watchdog
wtd = microcontroller.watchdog
wtd.timeout=2.5 # Set a timeout of 2.5 seconds
wtd.mode = watchdog.WatchDogMode.RAISE
I get the error:
  File "code.py", line 2, in <module>
ImportError: no module named 'watchdog'
I've also attempted running it like this:
wtd.mode = wtd.WatchDogMode.RAISE
and I get the error:
  File "code.py", line 4, in <module>
AttributeError: 'NoneType' object has no attribute 'timeout'
Is there an issue with the code I'm running or is watchdog incompatible with the board? I'm unsure of what to do. Thanks!
danhalbert
Re: Can't figure out how to use microcontroller.watchdog on MatrixPortal M4
Post by danhalbert »
What version of CircuitPython are you using? The version is given in the boot_out.txt file and in the initial printout in the REPL after you restart.
