I am building the NeoPixel Ring Lamp and am programming it
as a clock. I need to access individual leds but cannot find appropriate documentation and sample.py programs that will explain this. There is a alot of docs but I cannot find this. I did have to purchase some additional 60/4 rings due to the fragile nature of this ring.
NeoPixel access individual LEDs Pico W CircuitPython
- sethzarny
- sethzarny
Re: NeoPixel access individual LEDs Pico W CircuitPython
One other comment. I am programming this in CircuitPython on the Pico W. Thank you.
- adafruit_support_carter
The general syntax is:
where pixels is your NeoPixel object, i is the index of the LED you want to set, and color is the color.
pixels[i] = color
- sethzarny
Follow up question. I need to change the brightness of just one pixel LED. I see where you set the pixel brightness for all the pixels using this command:
pixels = neopixel.NeoPixel(board.GP1, 124, auto_write=False, brightness=0.15)
How do I change the brightness of just one pixel without effecting the others using CircuitPython? I am using a pixel to show the seconds and I need that pixel brighter than the rest. Thank you.
There's no individual pixel brightness setting. So this will have to be done by directly changing the color of that pixel. That is - reduce it's RGB values directly in the color setting.
