On PyPortal can't set attribute 'auto_brightness'
ghulse
Post by ghulse »
I recently updated CircuitPython on my PyPortal from 7.x to 8.0.3. My moon phase program that used to work fine now throws up this error:
File "code.py", line 384, in <module>
File "adafruit_pyportal/__init__.py", line 183, in __init__
File "adafruit_pyportal/peripherals.py", line 92, in __init__
File "adafruit_pyportal/peripherals.py", line 141, in set_backlight
AttributeError: can't set attribute 'auto_brightness'
line 384 in the code is: pyportal = PyPortal()
Any suggestions?
danhalbert
Re: On PyPortal can't set attribute 'auto_brightness'
Post by danhalbert »
It sounds like your libraries are out of date. Auto-brightness setting was removed from the PyPortal library last August. You can download the latest bundle and update manually, or you can use the "circup" tool: https://learn.adafruit.com/keep-your-ci ... ith-circup
ghulse
Post by ghulse »
Thanks, the circup tool updated all libraries. Thanks!
