So I tried it without the propmaker but the red light is still blinking. Could the feather be broken somehow ?
Maybe I could return it and ask for a new one in the shop where I got it in Germany.
Thank you
Darksaber Button not doing anything
- CptSchnauzbart
Re: Darksaber Button not doing anything
- 9A3437AE-6C82-44C5-81FF-566D0279777B.jpeg (83.92 KiB) Viewed 111 times
- 9651D59E-86DE-4652-8F75-D9F95332B4FE.jpeg (69.99 KiB) Viewed 111 times
- dastels
To be clear. When you connect En and Gnd it DOESN'T turn it off?
- CptSchnauzbart
That’s right. I connect the two pins with a cable and the red led still blinks.
- dastels
OK, that's not right.
Yes, you should talk to the shop you got it from. You can tell them that if it had been from Adafruit directly, I'd authorize a replacement.
- CptSchnauzbart
Thank you! Just emailed them with your answer attached. I’ll keep you updated.
- CptSchnauzbart
So they will refund me because they don’t have it in stock right now. Have to find a shop to order it. It costs a lot more in Germany. I can get it for 40€ from eBay.
- dastels
Good luck. It can still be hard to find boards in stock.
- CptSchnauzbart
Hello… it’s me xD
I got a new one and it’s working fine!
But now I got another „problem“ because even though I turn it off, it’s not completely shut down. I can hear a tiny noise coming out of the speaker as well as a wee red light coming from the neopixels. Is this supposed to be like that or how can I fix this issue.
thank you
thank you
- dastels
No. Connecting EN to ground (which the switch should do) should turn off power to the propmaker as well as the Feather.
Can you check the voltage on the V+ of the NeoPixel connector? It should be 0v when the switch is "off".
- CptSchnauzbart
I don’t have anything to measure but since I can see the neopixels glow red for a tiny bit I think it’s not 0.
- CptSchnauzbart
Could the battery that I am using be the issue ? That it’s too „powerful“? I’ll post a video tonight so that you can see what’s going on.
- dastels
If you're using a LiPo as called for, the battery shouldn't be the issue. Batteries can't really be "too powerful"; the circuit will take what it needs. The only concern is that the battery voltage is correct.
- CptSchnauzbart
So here’s a picture of the neopixels when button is off. The buttons led is off as well but the speaker makes a bit of noise and the pixels as you can see. I attached the battery I am using
- 6C278CD1-8639-4198-BE55-86CC2605374F.jpeg (429.16 KiB) Viewed 60 times
- 689C1EB7-2FB5-4697-96B1-DDE42AED6FA4.png (319.53 KiB) Viewed 60 times
- dastels
Hmm. That is odd.
I'm wondering about that battery. This is new information. Can you test with an Adafruit compatible Lipo? It *shouldn't* have the impact you're weeing, but you never know. That's an RC car battery.
Anyway, I'll ask around in support.
- CptSchnauzbart
