I've been having this ongoing problem in one of my high school classes. We're doing some IoT data monitoring on a variety of plants. Everything seems to work well for a couple of days, after which the microcontroller starts flashing red and needs to be reset to begin posting data again. There seems to be an MQTT failure. Upon reset, everything is fine again for another couple of days.
I've tried a "Try, Except" statement to avoid the error and even a hard microcontroller reset when the failure happens. It must be the code because it's happening on all devices. I'm using the ESP32-S2 Feather with circuit python. An example of the code can get seen here: https://github.com/LWHSTechnicalArts/De ... sensors.py
Thank you for any advice!
Problem consistently communicating with Adafruit.io data dashboard
- femur
- mikeysklar
Re: Problem consistently communicating with Adafruit.io data dashboard
Are you able to capture the failure on a REPL console?
Would it be crazy to reset the devices every night at midnight? While that is not a resolution to the issue it avoids the worse case scenario of code crashing on its own and not coming back.
- femur
Thank you for your reply. It's hard to capture in the REPL since I have to keep it plugged into a computer for a couple of days before it happens.
Resetting at midnight or after a certain time is an option; I'm just wondering why that might be necessary. I'm wondering if there's something I don't understand about communication using the MQTT protocol with the adafruit.io site. We're well under the data limits. It there may be something in the MQTT library that's timing out?
It seems to be pretty consistently happening around 36 hours into operations. But I'm not sure of the exact timing.
- mikeysklar
My guess would be a possible memory leak if the time to required reset is consistently in the 36 hours zone. You could explore it further with GC.
If you have a Raspberry Pi handy that can work well for trying to catch REPL crashes by plugging your boards into a Pi and having a remote console which can save everything.
- femur
Ahhh yes. This does seem like a strong possibility. I'll do some of the research you suggest. Thank you for these excellent suggestions!
- prabhu27390
Hi can someone help me to publish json document in adafruit mqtt server.
@prabhu27390 - Your post is off-topic. Please start a new thread for your question.
- femur
I'm still having the same issue consistently posting to an adafruit.io feed or dashboard. Everything works for a number of hours (usually between 12 and 48 hours), but then I get an MQTT error. I've been running the code with a debug window open and I'm getting this error (also attached as screenshots with more detail) :
- MMQTTExeception: PINGESP not returned from broker.
or
- OSError [Errno 128] ENOTCONN
I'm using Adafruit ESP32 Feather V2 - 8MB Flash + 2 MB PSRAM - STEMMA QT.
It's happening to me in my class with more than a dozen of these controllers.
It happens even with the suggested example like this one (I changed it to post every 100 seconds)
https://github.com/adafruit/Adafruit_Ci ... esp32s2.py
I tried using the:
gc.collect()
end_mem = gc.mem_free()
and I'm not seeing memory issues.
I've also tried resetting the microcontroller every few hours and using a try...except statement to bypass the error.
I'm stumped? Any more advice out there? Thank you!
or
I tried using the:
gc.collect()
- Screen Shot 2023-04-03 at 8.20.08 AM.png (33.02 KiB) Viewed 592 times
- Screen Shot 2023-04-03 at 1.39.18 PM.png (29.99 KiB) Viewed 592 times
- mikeysklar
Good job catching both error messages.
What does your try/except logic look like are you catching OSError?
Are you running CircuitPython 8.0.5 stable with current libraries?
try:
# replace this with whatever call is on line #102 of your code
except OSError as error:
print(error)
print("can't stop me now")
- femur
Thank you! I'm running circuit python 8.0.4 stable with matching libraries. However, when I first encountered the problem, I was running version 7 (which is to say I've tried both)
This is what I've been doing for the try except:
try:
mqtt_client.loop()
except:
print ("mqtt fail")
microcontroller.reset()
time.sleep(30)
pass
- mikeysklar
Use my error try/except which should help get passed that form of crash.
I would also try being more explicit and see if it makes a difference with MQTT.
Also it would be a good idea to update to the current libraries and CircuitPython so we can look into opening an issue with the github repo should the behavior continue after these minor try/except changes.
try:
mqtt_client.loop()
except MMQTTExeception as mqttissue:
print (mqttissue)
print (“trying again…mqtt issue”)
- femur
Thank you. I'll try this over the next days and let you know. Appreciate your help.
- mikeysklar
Looking forward to seeing what you find. My experience has been you need to be explicit with the except error catching and cannot use an empty except line.
- femur
Hello!
I'm still running into problems after about 48 hours of data posting. Now I'm getting the following error: 'MMQTTException' is not defined.
I did update to circuitpython 8.0.5 with the matching libraries.
Ideas?
Thank you!
Ideas?
Thank you!
- Screen Shot 2023-04-20 at 3.00.56 PM.png (16.61 KiB) Viewed 500 times
- Screen Shot 2023-04-20 at 12.57.51 PM.png (22.79 KiB) Viewed 500 times
- mikeysklar
MMQTTException is misspelled. Remove the extra 'e'.
