on ESP-32 S3 TFT reversed which has CircuitPython installed
My code as below:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import json
import board
import busio
import displayio
import digitalio
import adafruit_requests as requests
from digitalio import DigitalInOut
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
import adafruit_minimqtt.adafruit_minimqtt as MQTT
from adafruit_aws_iot import MQTT_CLIENT
### WiFi ###
# Get wifi details and more from a secrets.py file
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
# Get device certificate
try:
with open("aws_cert.pem.crt", "rb") as f:
DEVICE_CERT = f.read()
except ImportError:
print("Certificate (aws_cert.pem.crt) not found on CIRCUITPY filesystem.")
raise
# Get device private key
try:
with open("private.pem.key", "rb") as f:
DEVICE_KEY = f.read()
except ImportError:
print("Certificate (private.pem.key) not found on CIRCUITPY filesystem.")
raise
# If you are using a board with pre-defined ESP32 Pins:
#esp32_cs = DigitalInOut(board.ESP_CS)
#esp32_ready = DigitalInOut(board.ESP_BUSY)
#esp32_reset = DigitalInOut(board.ESP_RESET)
# If you have an externally connected ESP32:
esp32_cs = DigitalInOut(board.D9)
esp32_ready = DigitalInOut(board.D10)
esp32_reset = DigitalInOut(board.D5)
#spi = board.SPI()
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
# Verify nina-fw version >= 1.4.0
assert (
int(bytes(esp.firmware_version).decode("utf-8")[2]) >= 4
), "Please update nina-fw to >=1.4.0."
# Use below for Most Boards
status_light = neopixel.NeoPixel(
board.NEOPIXEL, 1, brightness=0.5
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, status_light)
### Code ###
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connect(client, userdata, flags, rc):
# This function will be called when the client is connected
# successfully to the broker.
print("Connected to MQTT Broker!")
print("Flags: {0}\n RC: {1}".format(flags, rc))
# Subscribe client to all shadow updates
print("Subscribing to shadow updates...")
aws_iot.shadow_subscribe()
def disconnect(client, userdata, rc):
# This method is called when the client disconnects
# from the broker.
print("Disconnected from MQTT Broker!")
def subscribe(client, userdata, topic, granted_qos):
# This method is called when the client subscribes to a new topic.
print("Subscribed to {0} with QOS level {1}".format(topic, granted_qos))
# Update device shadow with example JSON payload
payload = {"state": {"reported": {"moisture": 50, "temp": 30}}}
aws_iot.shadow_update(json.dumps(payload))
# We can also retrieve the shadow from AWS IoT,
# aws_iot.shadow_get()
# or delete the shadow
# aws_iot.shadow_delete()
def unsubscribe(client, userdata, topic, pid):
# This method is called when the client unsubscribes from a topic.
print("Unsubscribed from {0} with PID {1}".format(topic, pid))
def publish(client, userdata, topic, pid):
# This method is called when the client publishes data to a topic.
print("Published to {0} with PID {1}".format(topic, pid))
def message(client, topic, msg):
# This method is called when the client receives data from a topic.
print("Message from {}: {}".format(topic, msg))
# Set AWS Device Certificate
esp.set_certificate(DEVICE_CERT)
# Set AWS RSA Private Key
esp.set_private_key(DEVICE_KEY)
# Connect to WiFi
print("Connecting to WiFi...")
wifi.connect()
print("Connected!")
# Initialize MQTT interface with the esp interface
MQTT.set_socket(socket, esp)
# Set up a new MiniMQTT Client
client = MQTT.MQTT(broker=secrets["broker"], client_id=secrets["client_id"])
# Initialize AWS IoT MQTT API Client
aws_iot = MQTT_CLIENT(client)
# Connect callback handlers to AWS IoT MQTT Client
aws_iot.on_connect = connect
aws_iot.on_disconnect = disconnect
aws_iot.on_subscribe = subscribe
aws_iot.on_unsubscribe = unsubscribe
aws_iot.on_publish = publish
aws_iot.on_message = message
print("Attempting to connect to %s" % client.broker)
aws_iot.connect()
# Pump the message loop forever, all events
# are handled in their callback handlers
# while True:
# aws_iot.loop()
# Start a blocking message loop...
# NOTE: NO code below this loop will execute
# NOTE: Network reconnection is handled within this loop
while True:
try:
aws_iot.loop()
except (ValueError, RuntimeError) as e:
print("Failed to get data, retrying\n", e)
wifi.reset()
aws_iot.reconnect()
continue
time.sleep(1)
TimeoutError: ESP32 timed out on SPI select
It seems like SPI can't be used for this board, anyone has insights?
