MPR121 Capacitive Touch Sensor - False Detection
spagboi
Post by spagboi »
I am using an Arduino Leonardo and 12-Key Capacitive Touch Sensor Breakout MPR121 connected using a STEMMA QT.
When running the MPR121test sketch from the Adafruit MPR121 library, I am seeing that all inputs are being triggered roughly every 2 seconds. The trigger light on the MPR121 does not come on during these.
23:03:32.822 -> Adafruit MPR121 Capacitive Touch sensor test
23:03:32.878 -> MPR121 found!
23:03:33.854 -> 0 touched
23:03:33.854 -> 1 touched
23:03:33.854 -> 2 touched
23:03:33.854 -> 3 touched
23:03:33.854 -> 4 touched
23:03:33.854 -> 5 touched
23:03:33.854 -> 6 touched
23:03:33.854 -> 7 touched
23:03:33.854 -> 8 touched
23:03:33.854 -> 9 touched
23:03:33.854 -> 10 touched
23:03:33.854 -> 11 touched
23:03:33.854 -> 0 released
23:03:33.854 -> 1 released
23:03:33.854 -> 2 released
23:03:33.854 -> 3 released
23:03:33.854 -> 4 released
23:03:33.854 -> 5 released
23:03:33.854 -> 6 released
23:03:33.854 -> 7 released
23:03:33.854 -> 8 released
23:03:33.854 -> 9 released
23:03:33.854 -> 10 released
23:03:33.854 -> 11 released
23:03:33.901 -> 0 touched
23:03:33.901 -> 1 touched
23:03:33.901 -> 2 touched
23:03:33.901 -> 3 touched
23:03:33.901 -> 4 touched
23:03:33.901 -> 5 touched
23:03:33.901 -> 6 touched
23:03:33.901 -> 7 touched
23:03:33.901 -> 8 touched
23:03:33.901 -> 9 touched
23:03:33.901 -> 10 touched
23:03:33.901 -> 11 touched
23:03:33.901 -> 0 released
23:03:33.901 -> 1 released
23:03:33.901 -> 2 released
23:03:33.901 -> 3 released
23:03:33.901 -> 4 released
23:03:33.901 -> 5 released
23:03:33.901 -> 6 released
23:03:33.901 -> 7 released
23:03:33.901 -> 8 released
23:03:33.901 -> 9 released
23:03:33.901 -> 10 released
23:03:33.901 -> 11 released
23:03:34.135 -> 0 touched
23:03:34.135 -> 1 touched
23:03:34.135 -> 2 touched
23:03:34.135 -> 3 touched
23:03:34.135 -> 4 touched
23:03:34.135 -> 5 touched
23:03:34.135 -> 6 touched
23:03:34.135 -> 7 touched
23:03:34.135 -> 8 touched
23:03:34.135 -> 9 touched
23:03:34.135 -> 10 touched
23:03:34.135 -> 11 touched
23:03:34.135 -> 0 released
23:03:34.135 -> 1 released
23:03:34.135 -> 2 released
23:03:34.135 -> 3 released
23:03:34.135 -> 4 released
23:03:34.135 -> 5 released
23:03:34.135 -> 6 released
23:03:34.135 -> 7 released
23:03:34.135 -> 8 released
23:03:34.135 -> 9 released
23:03:34.135 -> 10 released
Otherwise, the board is correctly detecting real touches.
This is the MPR121test code:
This is a library for the MPR121 12-channel Capacitive touch sensor
Designed specifically to work with the MPR121 Breakout in the Adafruit shop
  ----> https://www.adafruit.com/products/
These sensors use I2C communicate, at least 2 pins are required
to interface
products from Adafruit!
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_MPR121.h"
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are 'released'
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
  Serial.begin(9600);
  while (!Serial) { // needed to keep leonardo/micro from starting too fast!
    delay(10);
  Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
  // Default address is 0x5A, if tied to 3.3V its 0x5B
  // If tied to SDA its 0x5C and if SCL then 0x5D
  if (!cap.begin(0x5A)) {
    Serial.println("MPR121 not found, check wiring?");
    while (1);
  Serial.println("MPR121 found!");
  // Get the currently touched pads
  currtouched = cap.touched();
  for (uint8_t i=0; i<12; i++) {
    // it if *is* touched and *wasnt* touched before, alert!
    if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" touched");
    // if it *was* touched and now *isnt*, alert!
    if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" released");
  // reset our state
  lasttouched = currtouched;
  // comment out this line for detailed data from the sensor!
  return;
  // debugging info, what
  Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t\t 0x"); Serial.println(cap.touched(), HEX);
  Serial.print("Filt: ");
    Serial.print(cap.filteredData(i)); Serial.print("\t");
  Serial.println();
  Serial.print("Base: ");
    Serial.print(cap.baselineData(i)); Serial.print("\t");
  Serial.println();
  // put a delay so it isn't overwhelming
  delay(100);
Please help!
mikeysklar
Re: MPR121 Capacitive Touch Sensor - False Detection
Post by mikeysklar »
Can you show a photo of your soldering and wiring between the Leonardo and MPR121.
Do you have any other controller you can use? Leonardos have some i2c compatibility issues.
