PyPortal Truncates Floats in JSON
macewmi
Post by macewmi »
I have the following code:
DATA_SOURCE = "https://exchange-rates.abstractapi.com/v1/live/?api_key=" + secrets['abstract'] + "&base=USD&target=CAD"
# {"base":"USD","last_updated":1679404500,"exchange_rates":{"EUR":0.927214}}
last_updated_LOCATION = ['last_updated']
EUR_LOCATION = ['exchange_rates', 'CAD']
cwd = ("/"+__file__).rsplit('/', 1)[0]
pyportal = PyPortal(url=DATA_SOURCE,
                    json_path=(EUR_LOCATION, last_updated_LOCATION),
                    text_font = cwd+"/fonts/6x10.bdf",
                    text_position=((5,25), (190, 25)),
                    text_color=(0xffff00, 0xffff00),
                    status_neopixel=board.NEOPIXEL,
                    default_bg=cwd+"/cta_black_splash.bmp"
pyportal.preload_font()
while True:
    try:
        value = pyportal.fetch()
    except RuntimeError as e:
        print("Some error occured, retrying! -", e)
    print(value)
    time.sleep(60)
In the while loop, value is [1.37061, 1679404500]. This is expected. But on the display, the 1.37061 displays as 1 and the 1679404500 displays as 1,679,404,500. The PyPortal seems to be formatting the data the way it wants to.
Can I easily prevent that from happening?
adafruit_support_mike
Re: PyPortal Truncates Floats in JSON
[moved to the CircuitPython forum]
neradoc
Post by neradoc »
Hi, numbers are formatted as ints by default in the pyportal library.
You can add a "text_transform" argument to PyPortal().
Here is an example:
import time
def _format_datetime(datetime):
    return "{}/{:02}/{:02} {:02}:{:02}:{:02}".format(
        datetime.tm_year,
        datetime.tm_mon,
        datetime.tm_mday,
        datetime.tm_hour,
        datetime.tm_min,
        datetime.tm_sec,
def transformer_rate(convert):
    return f"{convert:.3f}"
def transformer_location(convert):
    tt = time.localtime(convert)
    return _format_datetime(tt)
                    default_bg=cwd+"/cta_black_splash.bmp",
                    text_transform=(transformer_rate, transformer_location),
macewmi
Post by macewmi »
@neradoc, excellent! It's exactly what I needed to know. Thank you.
