Adafruit QT PY ESP32 Pico & Adafruit DRV2605L Haptic Motor Controller Circuit Not Working
For Adafruit customers who seek help with microcontrollers
techyhedgehog
Post by techyhedgehog »
https://cdn-shop.adafruit.com/product-v ... 305-05.mp4
The video that the link above leads to is what I am trying to replicate. I have an Adafruit QT Py ESP32 Pico - WiFi Dev Board with STEMMA QT - 8MB Flash 2MB PSRAM that is wired up to an Adafruit DRV2605L Haptic Motor Controller - STEMMA QT / Qwiic to which a Vibrating Mini Motor Disc is soldered. They are connected with a STEMMA QT / Qwiic JST SH 4-Pin Cable - 50mm Long.
However, any code I send, the vibrating mini motor does not vibrate. For example, I tried sending through the basic Example code from the Adafruit DRV2605L library. This was the code I tried to send through:
#include <Wire.h>
#include "Adafruit_DRV2605.h"
Adafruit_DRV2605 drv;
  Serial.begin(9600);
  Serial.println("Adafruit DRV2605 Basic test");
  if (! drv.begin()) {
    Serial.println("Could not find DRV2605");
    while (1) delay(10);
  drv.selectLibrary(1);
  // I2C trigger by sending 'go' command
  // default, internal trigger when sending GO command
  drv.setMode(DRV2605_MODE_INTTRIG);
uint8_t effect = 1;
//  Serial.print("Effect #"); Serial.println(effect);
   if (effect == 1) {
    Serial.println("11.2 Waveform Library Effects List");
  if (effect == 1) {
    Serial.println(F("1 − Strong Click - 100%"));
  if (effect == 2) {
    Serial.println(F("2 − Strong Click - 60%"));
  if (effect == 3) {
    Serial.println(F("3 − Strong Click - 30%"));
  if (effect == 4) {
    Serial.println(F("4 − Sharp Click - 100%"));
  if (effect == 5) {
    Serial.println(F("5 − Sharp Click - 60%"));
  if (effect == 6) {
    Serial.println(F("6 − Sharp Click - 30%"));
  if (effect == 7) {
    Serial.println(F("7 − Soft Bump - 100%"));
  if (effect == 8) {
    Serial.println(F("8 − Soft Bump - 60%"));
  if (effect == 9) {
    Serial.println(F("9 − Soft Bump - 30%"));
  if (effect == 10) {
    Serial.println(F("10 − Double Click - 100%"));
  if (effect == 11) {
    Serial.println(F("11 − Double Click - 60%"));
  if (effect == 12) {
    Serial.println(F("12 − Triple Click - 100%"));
  if (effect == 13) {
    Serial.println(F("13 − Soft Fuzz - 60%"));
  if (effect == 14) {
    Serial.println(F("14 − Strong Buzz - 100%"));
  if (effect == 15) {
    Serial.println(F("15 − 750 ms Alert 100%"));
  if (effect == 16) {
    Serial.println(F("16 − 1000 ms Alert 100%"));
  if (effect == 17) {
    Serial.println(F("17 − Strong Click 1 - 100%"));
  if (effect == 18) {
    Serial.println(F("18 − Strong Click 2 - 80%"));
  if (effect == 19) {
    Serial.println(F("19 − Strong Click 3 - 60%"));
  if (effect == 20) {
    Serial.println(F("20 − Strong Click 4 - 30%"));
  if (effect == 21) {
    Serial.println(F("21 − Medium Click 1 - 100%"));
  if (effect == 22) {
    Serial.println(F("22 − Medium Click 2 - 80%"));
  if (effect == 23) {
    Serial.println(F("23 − Medium Click 3 - 60%"));
  if (effect == 24) {
    Serial.println(F("24 − Sharp Tick 1 - 100%"));
  if (effect == 25) {
    Serial.println(F("25 − Sharp Tick 2 - 80%"));
  if (effect == 26) {
    Serial.println(F("26 − Sharp Tick 3 – 60%"));
  if (effect == 27) {
    Serial.println(F("27 − Short Double Click Strong 1 – 100%"));
  if (effect == 28) {
    Serial.println(F("28 − Short Double Click Strong 2 – 80%"));
  if (effect == 29) {
    Serial.println(F("29 − Short Double Click Strong 3 – 60%"));
  if (effect == 30) {
    Serial.println(F("30 − Short Double Click Strong 4 – 30%"));
  if (effect == 31) {
    Serial.println(F("31 − Short Double Click Medium 1 – 100%"));
  if (effect == 32) {
    Serial.println(F("32 − Short Double Click Medium 2 – 80%"));
  if (effect == 33) {
    Serial.println(F("33 − Short Double Click Medium 3 – 60%"));
  if (effect == 34) {
    Serial.println(F("34 − Short Double Sharp Tick 1 – 100%"));
  if (effect == 35) {
    Serial.println(F("35 − Short Double Sharp Tick 2 – 80%"));
  if (effect == 36) {
    Serial.println(F("36 − Short Double Sharp Tick 3 – 60%"));
  if (effect == 37) {
    Serial.println(F("37 − Long Double Sharp Click Strong 1 – 100%"));
  if (effect == 38) {
    Serial.println(F("38 − Long Double Sharp Click Strong 2 – 80%"));
  if (effect == 39) {
    Serial.println(F("39 − Long Double Sharp Click Strong 3 – 60%"));
  if (effect == 40) {
    Serial.println(F("40 − Long Double Sharp Click Strong 4 – 30%"));
  if (effect == 41) {
    Serial.println(F("41 − Long Double Sharp Click Medium 1 – 100%"));
  if (effect == 42) {
    Serial.println(F("42 − Long Double Sharp Click Medium 2 – 80%"));
  if (effect == 43) {
    Serial.println(F("43 − Long Double Sharp Click Medium 3 – 60%"));
  if (effect == 44) {
    Serial.println(F("44 − Long Double Sharp Tick 1 – 100%"));
  if (effect == 45) {
    Serial.println(F("45 − Long Double Sharp Tick 2 – 80%"));
  if (effect == 46) {
    Serial.println(F("46 − Long Double Sharp Tick 3 – 60%"));
  if (effect == 47) {
    Serial.println(F("47 − Buzz 1 – 100%"));
  if (effect == 48) {
    Serial.println(F("48 − Buzz 2 – 80%"));
  if (effect == 49) {
    Serial.println(F("49 − Buzz 3 – 60%"));
  if (effect == 50) {
    Serial.println(F("50 − Buzz 4 – 40%"));
  if (effect == 51) {
    Serial.println(F("51 − Buzz 5 – 20%"));
  if (effect == 52) {
    Serial.println(F("52 − Pulsing Strong 1 – 100%"));
  if (effect == 53) {
    Serial.println(F("53 − Pulsing Strong 2 – 60%"));
  if (effect == 54) {
    Serial.println(F("54 − Pulsing Medium 1 – 100%"));
  if (effect == 55) {
    Serial.println(F("55 − Pulsing Medium 2 – 60%"));
  if (effect == 56) {
    Serial.println(F("56 − Pulsing Sharp 1 – 100%"));
  if (effect == 57) {
    Serial.println(F("57 − Pulsing Sharp 2 – 60%"));
  if (effect == 58) {
    Serial.println(F("58 − Transition Click 1 – 100%"));
  if (effect == 59) {
    Serial.println(F("59 − Transition Click 2 – 80%"));
  if (effect == 60) {
    Serial.println(F("60 − Transition Click 3 – 60%"));
  if (effect == 61) {
    Serial.println(F("61 − Transition Click 4 – 40%"));
  if (effect == 62) {
    Serial.println(F("62 − Transition Click 5 – 20%"));
  if (effect == 63) {
    Serial.println(F("63 − Transition Click 6 – 10%"));
  if (effect == 64) {
    Serial.println(F("64 − Transition Hum 1 – 100%"));
  if (effect == 65) {
    Serial.println(F("65 − Transition Hum 2 – 80%"));
  if (effect == 66) {
    Serial.println(F("66 − Transition Hum 3 – 60%"));
  if (effect == 67) {
    Serial.println(F("67 − Transition Hum 4 – 40%"));
  if (effect == 68) {
    Serial.println(F("68 − Transition Hum 5 – 20%"));
  if (effect == 69) {
    Serial.println(F("69 − Transition Hum 6 – 10%"));
  if (effect == 70) {
    Serial.println(F("70 − Transition Ramp Down Long Smooth 1 – 100 to 0%"));
  if (effect == 71) {
    Serial.println(F("71 − Transition Ramp Down Long Smooth 2 – 100 to 0%"));
  if (effect == 72) {
    Serial.println(F("72 − Transition Ramp Down Medium Smooth 1 – 100 to 0%"));
  if (effect == 73) {
    Serial.println(F("73 − Transition Ramp Down Medium Smooth 2 – 100 to 0%"));
  if (effect == 74) {
    Serial.println(F("74 − Transition Ramp Down Short Smooth 1 – 100 to 0%"));
  if (effect == 75) {
    Serial.println(F("75 − Transition Ramp Down Short Smooth 2 – 100 to 0%"));
  if (effect == 76) {
    Serial.println(F("76 − Transition Ramp Down Long Sharp 1 – 100 to 0%"));
  if (effect == 77) {
    Serial.println(F("77 − Transition Ramp Down Long Sharp 2 – 100 to 0%"));
  if (effect == 78) {
    Serial.println(F("78 − Transition Ramp Down Medium Sharp 1 – 100 to 0%"));
  if (effect == 79) {
    Serial.println(F("79 − Transition Ramp Down Medium Sharp 2 – 100 to 0%"));
  if (effect == 80) {
    Serial.println(F("80 − Transition Ramp Down Short Sharp 1 – 100 to 0%"));
  if (effect == 81) {
    Serial.println(F("81 − Transition Ramp Down Short Sharp 2 – 100 to 0%"));
  if (effect == 82) {
    Serial.println(F("82 − Transition Ramp Up Long Smooth 1 – 0 to 100%"));
  if (effect == 83) {
    Serial.println(F("83 − Transition Ramp Up Long Smooth 2 – 0 to 100%"));
  if (effect == 84) {
    Serial.println(F("84 − Transition Ramp Up Medium Smooth 1 – 0 to 100%"));
  if (effect == 85) {
    Serial.println(F("85 − Transition Ramp Up Medium Smooth 2 – 0 to 100%"));
  if (effect == 86) {
    Serial.println(F("86 − Transition Ramp Up Short Smooth 1 – 0 to 100%"));
  if (effect == 87) {
    Serial.println(F("87 − Transition Ramp Up Short Smooth 2 – 0 to 100%"));
  if (effect == 88) {
    Serial.println(F("88 − Transition Ramp Up Long Sharp 1 – 0 to 100%"));
  if (effect == 89) {
    Serial.println(F("89 − Transition Ramp Up Long Sharp 2 – 0 to 100%"));
  if (effect == 90) {
    Serial.println(F("90 − Transition Ramp Up Medium Sharp 1 – 0 to 100%"));
  if (effect == 91) {
    Serial.println(F("91 − Transition Ramp Up Medium Sharp 2 – 0 to 100%"));
  if (effect == 92) {
    Serial.println(F("92 − Transition Ramp Up Short Sharp 1 – 0 to 100%"));
  if (effect == 93) {
    Serial.println(F("93 − Transition Ramp Up Short Sharp 2 – 0 to 100%"));
  if (effect == 94) {
    Serial.println(F("94 − Transition Ramp Down Long Smooth 1 – 50 to 0%"));
  if (effect == 95) {
    Serial.println(F("95 − Transition Ramp Down Long Smooth 2 – 50 to 0%"));
  if (effect == 96) {
    Serial.println(F("96 − Transition Ramp Down Medium Smooth 1 – 50 to 0%"));
  if (effect == 97) {
    Serial.println(F("97 − Transition Ramp Down Medium Smooth 2 – 50 to 0%"));
  if (effect == 98) {
    Serial.println(F("98 − Transition Ramp Down Short Smooth 1 – 50 to 0%"));
  if (effect == 99) {
    Serial.println(F("99 − Transition Ramp Down Short Smooth 2 – 50 to 0%"));
  if (effect == 100) {
    Serial.println(F("100 − Transition Ramp Down Long Sharp 1 – 50 to 0%"));
  if (effect == 101) {
    Serial.println(F("101 − Transition Ramp Down Long Sharp 2 – 50 to 0%"));
  if (effect == 102) {
    Serial.println(F("102 − Transition Ramp Down Medium Sharp 1 – 50 to 0%"));
  if (effect == 103) {
    Serial.println(F("103 − Transition Ramp Down Medium Sharp 2 – 50 to 0%"));
  if (effect == 104) {
    Serial.println(F("104 − Transition Ramp Down Short Sharp 1 – 50 to 0%"));
  if (effect == 105) {
    Serial.println(F("105 − Transition Ramp Down Short Sharp 2 – 50 to 0%"));
  if (effect == 106) {
    Serial.println(F("106 − Transition Ramp Up Long Smooth 1 – 0 to 50%"));
  if (effect == 107) {
    Serial.println(F("107 − Transition Ramp Up Long Smooth 2 – 0 to 50%"));
  if (effect == 108) {
    Serial.println(F("108 − Transition Ramp Up Medium Smooth 1 – 0 to 50%"));
  if (effect == 109) {
    Serial.println(F("109 − Transition Ramp Up Medium Smooth 2 – 0 to 50%"));
  if (effect == 110) {
    Serial.println(F("110 − Transition Ramp Up Short Smooth 1 – 0 to 50%"));
  if (effect == 111) {
    Serial.println(F("111 − Transition Ramp Up Short Smooth 2 – 0 to 50%"));
  if (effect == 112) {
    Serial.println(F("112 − Transition Ramp Up Long Sharp 1 – 0 to 50%"));
  if (effect == 113) {
    Serial.println(F("113 − Transition Ramp Up Long Sharp 2 – 0 to 50%"));
  if (effect == 114) {
    Serial.println(F("114 − Transition Ramp Up Medium Sharp 1 – 0 to 50%"));
  if (effect == 115) {
    Serial.println(F("115 − Transition Ramp Up Medium Sharp 2 – 0 to 50%"));
  if (effect == 116) {
    Serial.println(F("116 − Transition Ramp Up Short Sharp 1 – 0 to 50%"));
  if (effect == 117) {
    Serial.println(F("117 − Transition Ramp Up Short Sharp 2 – 0 to 50%"));
  if (effect == 118) {
    Serial.println(F("118 − Long buzz for programmatic stopping – 100%"));
  if (effect == 119) {
    Serial.println(F("119 − Smooth Hum 1 (No kick or brake pulse) – 50%"));
  if (effect == 120) {
    Serial.println(F("120 − Smooth Hum 2 (No kick or brake pulse) – 40%"));
  if (effect == 121) {
    Serial.println(F("121 − Smooth Hum 3 (No kick or brake pulse) – 30%"));
  if (effect == 122) {
    Serial.println(F("122 − Smooth Hum 4 (No kick or brake pulse) – 20%"));
  if (effect == 123) {
    Serial.println(F("123 − Smooth Hum 5 (No kick or brake pulse) – 10%"));
  // set the effect to play
  drv.setWaveform(0, effect);  // play effect
  drv.setWaveform(1, 0);       // end waveform
  // play the effect!
  drv.go();
  // wait a bit
  delay(500);
  effect++;
  if (effect > 117) effect = 1;
However, it sent the code to the QT Py, and hard reset via RTS pin, but after that the motor did not vibrate.
I am confident that the QT Py's condition is good because I uploaded the Blink sketch from the Neopixel library as shown in the QT Py Pico Arduino IDE setup tutorial and it works. Additionally, a green light lights up on the motor controller when power is sent through either a battery or from my computer through a wire.
Could someone please help me with the code and/or circuit or IDE to figure out why the motor wont vibrate when I send a sketch through?
Re: Adafruit QT PY ESP32 Pico & Adafruit DRV2605L Haptic Motor Controller Circuit Not Working
What do you see in the Serial Monitor when you run the example code?
techyhedgehog
�Adafruit DRV2605 Basic test
Please post some photos showing all your soldering and connections.
techyhedgehog
One wire of your motor wires is not connected. And the other does not appear to be soldered. However, that does not explain why the board is not detected.
Try running the i2c scanner code and post the results here.
https://learn.adafruit.com/scanning-i2c-addresses
techyhedgehog
I used the following code:
// i2c_scanner
// Modified from https://playground.arduino.cc/Main/I2cScanner/
#include <Wire.h>
// Set I2C bus to use: Wire, Wire1, etc.
#define WIRE Wire
  WIRE.begin();
  Serial.begin(9600);
  while (!Serial)
     delay(10);
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    WIRE.beginTransmission(address);
    error = WIRE.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
  else
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
and received the following response in the Serial Monitor:
I2C Scanner
Scanning...
OK. We can try replacing the DRV2605 board. If you purchased directly from Adafruit, please contact [email protected] with your order details and a link to this thread.
If you purchased from a reseller, please contact them directly and reference this thread as authorization for a replacement.
techyhedgehog
I actually ordered several DRV2605L boards. All of them lead to the same result. I was checking the serial monitor at a 9600 baud rate. Would changing that make a difference?
The serial port baud rate should not affect i2c communication.
Do you have another processor to test with? It could be a problem with the i2c bus on your QT Py.
techyhedgehog
I tried with another QT Py. I got the error listed below:
Sketch uses 290553 bytes (8%) of program storage space. Maximum is 3342336 bytes.
Global variables use 22760 bytes (6%) of dynamic memory, leaving 304920 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM3
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
Failed uploading: uploading error: exit status 2
Double-check that you have selected the right communications port. Sometimes the port number changes when re-connecting a device.
Return to “Microcontrollers”
