issues sending K33 CO2 sensor data to datalogging shield
mromero
Post by mromero »
I am running a metro AT328 (arduino board) with the adafruit datalogging shield with two K33ICB 10% CO2 sensors connected using I2C. I know the clock uses address 0x68 and the address for the sensors were changed to 0x69 and 0x56 respectively. The issue i am having is the co2 reading displays fine in the serial monitor but what i get on the SD card is 0,0 for the two sensors.
//2CO2_to_I2Cv4_logger
// CO2 Meter K-series Example Interface
// Revised by Marv Kausch, 7/2016 at CO2 Meter <co2meter.com>
// Talks via I2C to K30/K22/K33/Logger sensors and displays CO2 values
// 12/31/09
//03/21/2023 will attempt 2 read 2 K33 CO2 sensors by modifying Arduino_to_I2C code
//provided by vendor in explicit manner
#include <Wire.h>
#include <SD.h>//sd card
#include <SPI.h>
#include <RTClib.h>// clock
// We will be using the I2C hardware interface on the Arduino in
// combination with the built-in Wire library to interface.
// Arduino analog input 5 - I2C SCL
// Arduino analog input 4 - I2C SDA
  In this example we will do a basic read of the CO2 value and checksum verification.
  For more advanced applications please see the I2C Comm guide.
//int co2Addr =0;
int co2Addr1 = 0x69;// CO2 sensor 1
int co2Addr2 = 0x56;// CO2 sensor 2
int co2Value_1;
int co2Value_2;
// This is the default address:0x68 of the CO2 sensor, 7bits shifted left.  for sensor board 2 changed to 0X6A
RTC_PCF8523 rtc;// clock on datalogger
// create file
File myFile;
String Date,Time,CO2_1,CO2_2 ,Data;
void setup() {//=============================================================
  //start clock
    rtc.begin();
  //serial
  Serial.begin(9600);
  delay(2000);
   //clock
 if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    Serial.flush();
    while (1) delay(10);
    if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running, let's set the time!");
    // When time needs to be set on a new device, or after a power loss, the
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
  }  // close clock
  // SD card initialize
  Serial.print("Initializing SD card...");
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  myFile = SD.open("data.txt", FILE_WRITE);
  if (myFile) {
    myFile.println( "Date, Time, CO2_1(ppm), CO2_2(ppm)) \r\n");
    myFile.close();
  else {
    Serial.println("error opening data.txt");
  Wire.begin ();
  pinMode(13, OUTPUT); // address of the Arduino LED indicator
  Serial.println("Application Note AN-102: Interface Arduino to two  K-333");
}//==================================================== close setup Loop
// Function : int readCO2_1()
// Returns : CO2 Value upon success, 0 upon checksum failure
// Assumes : - Wire library has been imported successfully.
// - LED is connected to IO pin 13
// - CO2 sensor address is defined in co2_addr
int readCO2_1()
{//+++++++++++++++++++++++++++++++++++++++++++++++++  read CO2()function definition
  int co2_value_1 = 0;  // We will store the CO2 value inside this variable.
  digitalWrite(13, HIGH);  // turn on LED
  // On most Arduino platforms this pin is used as an indicator light.
  /* Begin Write Sequence */
  Wire.beginTransmission(0x69);
 // Wire.beginTransmission(co2Addr1);
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  Wire.endTransmission();
  /* End Write Sequence. */
    We wait 10ms for the sensor to process our command.
    The sensors's primary duties are to accurately
    measure CO2 values. Waiting 10ms will ensure the
    data is properly written to RAM
  delay(10);
  /* Begin Read Sequence */
    Since we requested 2 bytes from the sensor we must
    read in 4 bytes. This includes the payload, checksum,
    and command status byte.
  Wire.requestFrom(0x69, 4);
  byte i = 0;
  byte buffer[4] = {0, 0, 0, 0};
    Wire.available() is not nessessary. Implementation is obscure but we leave
    it in here for portability and to future proof our code
  while (Wire.available())
    buffer[i] = Wire.read();
    i++;
  /* End Read Sequence */
    Using some bitwise manipulation we will shift our buffer
    into an integer for general consumption
  co2_value_1 = 0;
  co2_value_1 |= buffer[1] & 0xFF;
  co2_value_1 = co2_value_1 << 8;
  co2_value_1 |= buffer[2] & 0xFF;
  byte sum = 0; //Checksum Byte
  sum = buffer[0] + buffer[1] + buffer[2]; //Byte addition utilizes overflow
  if (sum == buffer[3])
    // Success!
    digitalWrite(13, LOW);
    return co2_value_1;
  else
    // Failure!
      Checksum failure can be due to a number of factors,
      fuzzy electrons, sensor busy, etc.
    return 0;
}//++++++++++++++++++++++++++++++++++++++++++ close the read CO2 function definition
// Function : int readCO2_2()
int readCO2_2()
  int co2_value_2 = 0;  // We will store the CO2 value inside this variable.
  Wire.beginTransmission(0x56);
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  delay(10);
  Wire.requestFrom(0x56, 4);
  byte i = 0;
    i++;
  co2_value_2 = 0;
  co2_value_2 |= buffer[1] & 0xFF;
  co2_value_2 = co2_value_2 << 8;
  co2_value_2 |= buffer[2] & 0xFF;
    // Success!
    return co2_value_2;
  else
    // Failure!
    return 0;
void loop() {//#####################################################void loop
   // make a string for assembling the data to log:
     data_logging();
     delay(10000);//time between writting to sd card: delay(ms) 1000=1sec ; 900,000=15 min use this for final use 20,000 for testing
 //once for sensor1 ADDRESS0x69//****************************************************************
 // int co2Value = readCO2();// orig
 int co2Value_1 = readCO2_1()*10;// what i was told to do. this gives half of what the dev kit prewired one reads.
  if (co2Value_1 > 0)
    Serial.print("CO2 Value1: ");
    Serial.println(co2Value_1);
  else
    Serial.println("Checksum failed / Communication failure");
  delay(2000);
  //********************************************************************done with CO2value1
//once for sensor2 ADDRESS0x56//****************************************************************
 int co2Value_2 = readCO2_2()*10;// what i was told to do. this gives half of what the dev kit prewired one reads.
  if (co2Value_2 > 0)
    Serial.print("CO2 Value2: ");
    Serial.println(co2Value_2);
  else
  delay(2000);
}//##############################################################################close loop
//--------------------subroutines------------------------------------
void data_logging() {
//  String CO2_1 = String(co2Value_1);
//  String CO2_2 = String(co2Value_2);
//  Data = CO2_1 + "," + CO2_2  ;
  Serial.print("Save data: ");
  Serial.println(Data);
  if (myFile) {
    Serial.print("Writing to data.txt...");
    //time stamp
    DateTime now = rtc.now();
    myFile.print(now.year(), DEC);
    myFile.print('/');
    myFile.print(now.month(), DEC);
    myFile.print('/');
    myFile.print(now.day(), DEC);
    myFile.print(",");
    myFile.print(now.hour(), DEC);
    myFile.print(':');
    myFile.print(now.minute(), DEC);
    myFile.print(",");//delimeter between time and data
   // myFile.println(Data);//ln adds carriage return
   myFile.print(co2Value_1);
   myFile.print(" , ");
   myFile.println(co2Value_2);
    myFile.close();
    Serial.println("done.");
  } else {
  Serial.println();
output file.png (8.89 KiB) Viewed 177 times
serial console.png (16.93 KiB) Viewed 177 times
Re: issues sending K33 CO2 sensor data to datalogging shield
In your loop, you are reading and printing the value of a local variable declared here:
In your data_logging function, you are logging the value of the global variable (with the same name) declared here:
int co2Value_1;
Sine the global variable is never initialized or assigned to, it always logs zero.
mromero
Post by mromero »
I thought i had initiallized it when i wrote:
int co2Value_1;
int co2Value_2;
outside the void set up and void loop. was i supposed to initialize in a different way.
thanks for the help in advance
int co2Value_1;
int co2Value_2;
That is just a declaration of two variables at global scope. It does not initialize anything.
In your loop you declare a new variable at local scope. And you assign it the value of the current co2 reading.
This new variable just happens to have the same name as the one you declared at global scope. But it is not the same variable!
A few lines later, you print the value of the local variable:
  if (co2Value_1 > 0)
However, in your data_logging function you are printing the value of the global variable which has never had a value assigned to it.
To fix this, you can just eliminate the declaration of the local variables in your loop and just assign the co2 readings to the global variables. In other words:
change this:
to this:
https://www.tutorialspoint.com/cplusplu ... _scope.htm
