I'm working with the Arduino UNO R3 and the Adafruit 1.8" TFT V2 shield.
Libraries installed:
Adafruit GFX Library
Adafruit_Bus I/O
Adafruit ST7735 Library
Adafruit seesaw Library
Result:
seesaw started
Version: 24FF
TFT OK!
Initializing SD card...failed
But I get only a white screen with no display => no chance when pressing the buttons.
So I tried some other tests:
graphic test
graphic test_pybadge_pygamer (Option 2)
Also white screen und no display.
Any suggestions?
Thx
Felix
Adafruit 1.8" TFT shield MicroSD and Joystick white screen, no display
- cw_orange
- mikeysklar
Re: Adafruit 1.8" TFT shield MicroSD and Joystick white screen, no display
Can you post a photo of your setup. Just to verify the soldering or anything unusual.
Since you get a working display and no SD card can you tell me more about the specs on the SD card and how it was formatted?
- cw_orange
This is my Setup:
- Setup2.png (653.67 KiB) Viewed 183 times
- cw_orange
I have a microSD card formatted in FAT32 with 4GB. I use .bmp files with 24bit RGB and 128x160 Pixel or 48x48 Pixel, stored all in the root. The shield has a microSD card reader, which I use.
- mikeysklar
Try going over the soldering one more time with an iron (all pins). The pins in the top right corner Digital I/O 0-7 look like cold joints kinda of blobby and not fully melted.
- cw_orange
Thanks, was worth a try, unfortunately without success
- mikeysklar
Looking at your board photo you soldered the ICSP header on the wrong side. That black 2x3 (6-pin) connector (far right in your photo) is supposed to be face down so you have access to the SPI pins.
- cw_orange
Thank's that is correct, my mistake
