"No pull up found" error with SCD-30 and RPi Pico W
VinnySauce
Post by VinnySauce »
Hi all,
I've been trying to set up my Adafruit SCD-30 breakout board with a Raspberry Pi Pico W board and CircuitPython.
I've wired up the SCD-30 using a STEMMA connector as shown here: https://imgur.com/6QNNjwa
I'd expect the following code to work:
import board
import busio
i2c = busio.I2C(board.GP1, board.GP0)
However when I run this I receive the following error message:
Trying GP1 and GP0:
  File "code.py", line 6, in <module>
RuntimeError: No pull up found on SDA or SCL; check your wiring
It is my understanding that the SCD-30 breakout board includes 10k pull-up resistors for the SDA and SCL lines, so I shouldn't need to add my own I2C pull-up resistors. Am I doing something wrong?
Thanks in advance!
danhalbert
Re: "No pull up found" error with SCD-30 and RPi Pico W
Post by danhalbert »
From the photo, it appears that you have not soldered the header pins onto the board. You cannot get good connections without soldering the pins. The error you are seeing would be a symptom of that.
VinnySauce
danhalbert wrote: Fri Mar 24, 2023 11:57 am From the photo, it appears that you have not soldered the header pins onto the board. You cannot get good connections without soldering the pins. The error you are seeing would be a symptom of that.
You're absolutely right - getting the pins at the right angle resolves this issue. Soldering iron ordered! Many thanks for your help.
