Hi guys and gals,
Full disclosure my coding skills are pretty bad. But, I'm working on a project where I would be able to read a pressure or vacuum reading in a small hand held devise. I'm hoping I can do it with just these 2 products:
Pressure sensor:
https://www.adafruit.com/product/3965
ESP32 Board:
https://learn.adafruit.com/esp32-s2-rev ... er/pinouts
My issue will be the coding. I'd like to have a display in PSI, inches of vacuum, and hectopascal. How difficult do you think it would be to program this? I wonder if I can ask GPT this question...
Any help would be awesome thanks guys!
Might need some coding help.
Re: Might need some coding help.
There is example code in the library that displays PSI and hPa. You can start with that.
https://learn.adafruit.com/adafruit-mpr ... duino-test
Convertng to inHg from PSI is as simple as applying a conversion factor: https://www.sensorsone.com/inhg-to-psi- ... ion-table/
- flygremlin
Hi guys,
So I got this feather today and I'm trying to load my .py code to it. But when I drag the code and or libraries to the drive and eject it. it doesn't save anything. I must be missing something but I have no idea what. Any ideas?
I'm not an expert on the Python side of things. Probably best to post that question in the CircuitPython part of the forum here: posting.php?mode=post&f=60
