Matrix Portal M4
jm2915
Matrix Portal M4
Post by jm2915 »
When attempting to load circuitpython onto my matrix portal M4, I accidentally deleted all the pre-installed contents of the M4. I tried resetting and installing the bootloader, then installing the latest version of circuitpython, but it doesn't appear to be successful.
Any ideas?
danhalbert
Re: Matrix Portal M4
Post by danhalbert »
Hi - you copied the UF2 file to the CIRCUITPY drive. You need to copy it to the MATRIXBOOT drive. Delete it from the CIRCUITPY drive. Double-click the reset button to get the MATRIXBOOT drive. Details are here:
https://learn.adafruit.com/adafruit-mat ... cuitpython
I recommend you turn on showing filename extensions all the time in Windows: it makes things much clearer:
jm2915
Post by jm2915 »
Thanks for the message!
I deleted and then reset. Matrixboot became circuitpy, but the only item appears to be the boot_out.txt file. I've done it a handful of times, so I'm not sure what's happening with it.
Screenshot 2023-03-26 190908.png (37.86 KiB) Viewed 40 times
danhalbert
That makes sense; there was only `boot_out` (not showing the `.txt`) in your first screenshot, besides the .uf2.
To get a default "Hello World" into code.py, you can do this in the Mu Serial window, typing into the REPL:
import storage
storage.erase_filesystem()
That erases and reformats CIRCUITPY, and puts in some default files, most of which are present only to prevent certain problems on macOS.
