"rainbow.period = VARIABLE" not working?
RGB_Dude
Post by RGB_Dude »
import neopixel
import board
import digitalio
import time
from adafruit_led_animation.animation.rainbow import Rainbow
numpix = 32
pixels = neopixel.NeoPixel(board.GP5, numpix, brightness=1, auto_write=True)
pixels.fill(0)
pixels.show()
time.sleep(0.01)
presses = 1
SPEED = 1
button = digitalio.DigitalInOut(board.GP6)
button.switch_to_input(pull=digitalio.Pull.UP)
rainbow = Rainbow(pixels, speed=0, period=SPEED, step=2.4, precompute_rainbow=True)
while True:
        if not button.value:
            presses = presses + 1
            if presses > 10:
                SPEED = 1
                presses = 1
                print("Speed reset:", SPEED, presses)
            elif presses < 11:
                SPEED = SPEED + 5
                print("Speed decreased:", SPEED, presses)
            time.sleep(0.2)
        rainbow.period = SPEED
        rainbow.animate()
Why is this not working? The rainbow animation works fine of course, but the speed (the period variable) only affects the animation speed if changed manually at the beginning when defining the animation. Later in the code it seemingly cannot be changed or at least nothing happens. The code still runs fine.
Am I doing something wrong? "rainbow.speed = VARIABLE" does work by the way, but it doesn't affect the animation speed in a strict sense of the word. Is there anything to update the rainbow.period during "while true"?
PS.
rainbow.generate_rainbow()
rainbow.reset()
these also don't seem to have any effect
