Need to hire for micro-controller programming, where do I go?
Toonces
Post by Toonces »
I'm designing a display piece that needs to be lit with what I'm imagining to be a small cluster of LED lights, maybe something similar to a puck light, but I need to custom program the light sequence. I've recently seen a video on how you can use an arduino to run custom LED light programs, but I have no such programming knowledge and I'm not sure using an arduino, necessarily, is the only way to get this done. I need to contract someone to write an arduino program to run LED lights and teach me how to put together such a light system, as well as flash the program to new processors.
Where should I go? ... On Fiverr or elsewhere on the web to request this kind of job?
barshatriplee
Re: Need to hire for micro-controller programming, where do I go?
Post by barshatriplee »
You have already mentioned fiverr. You can also post your requirement to BANNED.com
There are many Arduino and Microcontroller experts over there.
Toonces
Post by Toonces »
Thank you! I'll check it out.
Franklin97355
Post by Franklin97355 »
We have a jobs board that is going under rehab. Check it out if you have no luck.
leef_me22
Post by leef_me22 »
Are you still needed a programmer?
