Map block formatting
richardek
Post by richardek »
Hi!
What is the correct formatting of latitude and longitude in the feed for the map block in dashboards? :)
Thank you!
mikeysklar
Re: Map block formatting
Post by mikeysklar »
This bit might help the format:
https://cdn-learn.adafruit.com/download ... cs-gps.pdf
The Adafruit IO MQTT CSV feed topic expects data published in the following format:
sensor_value,latitude,longitude,elevation
So if we were sending speed in MPH as our sensor value, the data would look like
this:
23,39.283277, -76.611818,10
richardek
Post by richardek »
Thank you for your reply mikeysklar!
I tried that, but the map is still stuck over New York =/
mikeysklar
Can you post your code? Maybe something is off syntax wise?
brubell
Learn User Page
Post by brubell »
Please post your code
richardek
Post by richardek »
Here is my feed. I have tried to add the value but the map widget is still showing New York.
Screenshot 2023-04-01 204002.jpg (67.37 KiB) Viewed 205 times
Screenshot 2023-04-01 211526--.jpg (50.22 KiB) Viewed 205 times
mikeysklar
We will still need to see the code to assist you. The values shown are in the feed match the mapping for NYC.
richardek
Post by richardek »
Do I need to code anything for the map block to work? I'm just sending the coordinates from my microcontroller (Arduino C++)
mikeysklar
The code on your microcontroller is what we want to see. There could be some sort of syntax issue or incorrect API usage.
richardek
Post by richardek »
Thanks for you reply mikeysklar, here it is =)
char position[] = "23,59.8050101,17.6260959,10";
// Publish the data as raw data to the MQTT server
mqtt.pubRaw(DEFAULT_LINK_ID, "my-account/feeds/position", position);
mikeysklar
Looking at the docs for location publishing you might want to try publishing as CSV instead of pubraw.
https://io.adafruit.com/api/docs/mqtt.h ... ending-csv
Sending CSV
Alternatively, you can send location tagged data to /csv topics. In this example, that would be the topic mosfet/feeds/photocell-one/csv instead of mosfet/feeds/photocell-one. Both store data in the same feed. The format IO expects for location tagged CSV data is VALUE, LATITUDE, LONGITUDE, ELEVATION.
With the example data shown before, that means you could publish the string "22.587,38.1123,-91.2325,112" to mosfet/feeds/photocell-one/csv. to store the value "22.587" in the location latitude: 38.1123, longitude: -91.2325, elevation: 112.
richardek
Post by richardek »
Oh that's a great point!! I'll try that.
Thank you mikeysklar! :D
richardek
Post by richardek »
Yess!! That made it! 😃🙏
Thank you so much mikeysklar!
mikeysklar
Cool, what syntax did you end up using? Can you paste it in for other that get hung up on this.
richardek
Post by richardek »
Just added the /csv at the end of the topic address. =D
mqtt.pubRaw(DEFAULT_LINK_ID, "my-account/feeds/position/csv", position);
