i need help with my purchase
- Lucasealey
i recently bought Adafruit Audio FX Sound Board + 2x2W Amp - WAV/OGG Trigger -16MB from the pie hut and when i went to load sound files into it, the soundboard only had 16KB of storage instead of the 16MB it was supposed to have, i was wondering if i can fix this or do i have to return it as i have already used it as part of my project so i cannot return it
- adafruit_support_carter
Re: i need help with my purchase
It might just be an incorrect reading.
Is the folder showing up OK and generally letting you copy audio files to it?
https://learn.adafruit.com/adafruit-aud ... udio-files
- Lucasealey
no when i try to put files in which are 2 mb it says that there is not enough storage as there is 16kb in the folder
It sounds like a folder is showing up though? Is it showing other content already loaded there?
- Lucasealey
just one thing which is like 5kb and comes with the soundboard
Can you post a screen shot of the current contents?
Also, turn off any "don't show hidden files" feature that might be turned on in your OS's file explorer.
