I am working on a simple display with an LED screen to fetch from an http server within a raspberry pi on my local network and display the value it returns on the screen. It connects just fine several times and displays the values properly, but after a few minutes it hangs on a connection and the display halts while this occurs. The only solution I have seen so far is to unplug it and plug it back in, but within a few minutes it starts hanging on the connection again.
I saw reference of a settimeout() function on https://docs.circuitpython.org/projects ... t/api.html. I have not been able to figure out how to use it though.
Here is the relevant code
def getRaspberryData():
global display_text
try:
print("Fetching text from", raspberry_url)
r = requests.get(raspberry_url)
display_text = r.text
r.close()
print('received: ' + display_text)
return display_text
except Exception as e:
print('error getting display text', e)
return display_text
def initialSetup():
global raspberry_url
# Get wifi details and more from a secrets.py file
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
raspberry_url = secrets["raspberry"]
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
requests.set_socket(socket, esp)
print("Connecting to AP...")
while not esp.is_connected:
try:
esp.connect_AP(secrets["ssid"], secrets["password"])
except OSError as e:
print("could not connect to AP, retrying: ", e)
continue
getRaspberryData()
received: Test message
Fetching text from http://[my-server-ip]:8000/output.txt
(It seems to only occur when reaching out to the local raspberry pi, but I can still reach it from other devices on the network so I'm not sure what's going on with it)
