Hi - you sell many external light sensors, so I'm not sure which one to choose that will be compatible with the CPB. I just need it to measure ambient light.
glenn
External Light Sensor for CPB
- adafruit_support_carter
Re: External Light Sensor for CPB
There is already a light sensor on the CPB itself:
https://learn.adafruit.com/adafruit-cir ... rs-3039274
that can be used for ambient light measurement.
Are you also looking for a secondary / external one?
- gwilcox123
yes, we are looking for a way to place a light sensor some distance from the board. So would need an external unit that could be wired back to the board.
thx!
g.
thx!
g.
In general, you could probably interface with any of these boards:
https://www.adafruit.com/category/61
What kind of distance will there be between the CPB and the sensor location?
Do you have any special requirement for type of light? Like UV, etc?
- gwilcox123
Thanks for your reply! We will place the sensor only a foot or two from the board. Something that would work in a general interior ambient light. It doesn't necessarily have to read UV light.
thx!
g.
thx!
g.
For that distance, any of the I2C based option should work:
https://www.adafruit.com/product/5610
https://www.adafruit.com/product/5591
https://www.adafruit.com/product/4681
https://www.adafruit.com/product/4162
There is a STEMMA QT cable available with alligator clips that would allow connecting to the CPB without any soldering:
https://www.adafruit.com/product/4398
Another option would be to use any of those STEMMA QT cables and strip the wires on one end and attach to the CPB using bolts:
https://www.adafruit.com/product/4103
- petespaco
What not simply use product 161, a CdS photo cell? (USD $0.95)
That's another option:
https://www.adafruit.com/product/161
It's a purely analog sensor. But the CPB has analog inputs that could be used to read it. There's a general guide here that shows basic usage:
https://learn.adafruit.com/photocells/using-a-photocell
