This is CircuitPython 8.0.5, the latest bugfix revision of CircuitPython, and is a new stable release.
Notable changes to 8.0.5 since 7.3.0
See the CircuitPython 8.0.0 release notes for full information about changes in 8.0.x since 7.3.0.
Download from circuitpython.org
Firmware downloads are available from the downloads page on circuitpython.org. The site makes it easy to select the correct file and language for your board.
Installation
To install follow the instructions in the Welcome to CircuitPython! guide. To install the latest libraries, see this page in that guide.
Try the latest version of the Mu editor for creating and editing your CircuitPython programs and for easy access to the CircuitPython serial connection (the REPL).
Documentation
Documentation is available in readthedocs.io.
Port status
CircuitPython has a number of "ports" that are the core implementations for different microcontroller families. Stability varies on a per-port basis. As of this release, these ports are consider stable:
- atmel-samd: Microchip SAMD21, SAMx5x
- cxd56: Sony Spresense
- espressif: Espressif ESP32-S2
- nrf: Nordic nRF52840, nRF52833
- raspberrypi: Raspberry Pi RP2040
- stm: ST STM32F4 chip family
- broadcom: Raspberry Pi boards such as RPi 4, RPi Zero 2W
- espressif: ESP32, ESP32-S3, ESP32-C3
- litex: fomu
- mimxrt10xx: NXP i.MX RT10xxx
- stm: ST non-STM32F4 chip families
Fixes and enhancements
- Prevent startup loop when settings.toml is edited. #7810. Thanks @jepler.
- Make build_board_info.py fetch files.json properly when it is larger than 1MB. #7728. Thanks @Neradoc and @dhalbert.
- ESP32-S3 has significant issues with I2C devices that sleep or use clock stretching. Retry operations on these devices as necessary, or use ESP32-S2 boards.
- Espressif boards have ESP-IDF storage leaks and occasionally crash after extended WiFi use.
- See https://github.com/adafruit/circuitpython/issues for other issues, including issues still to be addressed for:
Thank you to all who used, tested, and contributed since 8.0.4, including the contributors above, and many others on GitHub and Discord. Join us on the Discord chat to collaborate.
