Hi all,
I have a problem where a Trinket M0 isn't recognized on boot on a Win7 64-bit machine. If I unplug/replug it it works fine, just not seen on boot. I used a couple drivers, including the drivers from adafruit (the green box that says "download the latest drivers" where you unplug and run the EXE). In device manager it still shows a little "caution" icon on CIRCUITPY Audio Device but it works fine. I have not found a way to get rid of the Caution.
I'm using this for a volume/mute knob and replugging every time you restart is a hassle. Even worse is I'm using this in a bartop arcade machine where it's shelled to not-windows so replugging (or mouse or k/b) is out of the question. No, I'm not having these problems in shelled-mode, I'm still playing with vanilla W7. I boot to the standard desktop, no volume control. Replug and it comes back no problem. Restart, no volume control again. I'd like this thing to be recognized just like a standard mouse on boot.
Is this a problem where the little Caution symbol isn't letting Win7 see it on startup, like it's not authorized? Is there a better driver? I wish I was back in the autoexec.bat and boot.ini days sometimes.
Any ideas?
Trinket M0 not recognized on boot, W7 64
Re: Trinket M0 not recognized on boot, W7 64
Try adding some code that waits maybe 100ms, checks for a Serial connection, and executes NVIC_SystemReset() if it doesn't see one. That should be equivalent to unplugging and replugging.
- dkoh
Thank you, I'll try it out. I did play with devcon and it would remove, rescan, make the USB "du-DUN" noise, and the folder showed back up, but still no volume action. I tried on a second W7 machine and it worked perfectly after 3 consecutive restarts. I guess it's just the way Intel handles USB on this board.
Yeah, in practice USB ends up being a combination of the specified behavior and the stylistic choices OS developers make when implementing the spec. You have to cope with both.
