I am running a simple script to connect to WiFi, blink onboard neopixel, then go to deep sleep. For the first loop, everything works correctly, including the welcome webpage that is served by my device. (Adafruit Feather ESP32-S2)
After the deep sleep completed and the loop restarts, the blinking continues as expected, but the welcome webpage is no longer reachable. (using Fing I can still see it connected on my network, though)
Any thoughts on this? I don't want to physically hit the reset button to gain access to update the device in the future, as these will be for iot project.
Circuitpython web page gone after deep sleep
- mikebabin
- mikeysklar
Re: Circuitpython web page gone after deep sleep
Are you able to reproduce this wake from deep sleep issue using the current stable CircuitPython 8.0.5.
- mikebabin
I was on 8.0.3 and just tried on 8.0.5, same problem. Thanks
- mikeysklar
Is your board waking up in safe mode? Yellow NeoPixel LED flashing on the board?
There have been two somewhat related issues which have been resolved. I'll mention them just because they include some minimal sample code for reproducing.
1. deep sleep works first time
2. deep sleep brownout detection conflict
Something to quickly test would be resetting the WIFI when coming out of deep sleep.
3 YELLOW blinks: CircuitPython is in safe mode. No user code was run. Check the serial console for safe mode reason.
wifi.reset()
- tannewt
It was by design that the web workflow doesn't start after deep sleep. The goal is to reduce start up time from deep sleep to minimize power use of a wake up.
We merged a PR to change this but are unsure what the right behavior is. https://github.com/adafruit/circuitpython/pull/7814
