I have a Circuit Playground Express embedded into an enclosure. I'm using the Adafruit USB Type C Breakout Board (4090) so that I have a plug accessible from the back of the enclosure.
This works just fine for power, but I can't figure out how to get data to work so I can reprogram the Circuit Playground Express when plugged into a computer.
I have a micro-usb cable plugged into the Circuit Playground Express, and the other side soldered to the breakout board (VBUS, GND, D+, D-). When I plug it into a computer I get power just fine, but the Circuit Playground Express isn't detected on the computer.
I'm sure I'm missing something, but I'm not sure what.
Thanks.
USB Breakout Board
- dastels
Re: USB Breakout Board
USB C is a bit different due to the power and flexibility it brings. See https://learn.adafruit.com/understandin ... s-and-more for more information.
This would do the job, but might be too long: https://www.adafruit.com/product/4056
- ryantollefson
Thanks for the suggestion & the link, and that would probably work well under different circumstances...
Unfortunately, I was planning on going to another PCB first with plugs to power several inductive coils & a servo (I didn't want to run power for those through the Circuit Playground).
I've been trying to read & understand Microchip's Introduction to USB-C here: http://ww1.microchip.com/downloads/en/a ... 01953a.pdf
As I understand it, the Adafruit breakout board I have (https://www.adafruit.com/product/4090) is configured as an Upstream Facing Port with 5.1K resistors on CC1 & CC2.
I thought this would work to just wire to the micro-usb port on the Circuit Playground, but apparently not. The best I can come up with is there is something about going back to the micro-USB port that makes it not work. That perhaps what I really need is a breakout board that acts more like a USB-C hub or a downstream facing port instead (think like a USB-C -> USB-A female cable). If this is the case, I might need to change to 22K pull-up resistors instead of the 5.1K pull-down that are on there now?
If I were to do that though, I'm not sure I could still get power out of it the same way?
- dastels
I'll see if anyone else in support has some input.
- adafruit2
post up some clear photos of your wiring. probably some soldering issue or D+ / D- are swapped
- ryantollefson
Thank you for the reply!
I can certainly redo the connections if needed, but I did trace everything from the breakout board back to the CPE, and I get continuity on Red, Black, Green, & White all the way through to the surface mount connectors on the CPE.
Maybe D+ & D- are swapped? I just stuck with the white/green color cables and assumed it was good.,
- CircuitPlayground.jpg (955.28 KiB) Viewed 130 times
- breadboard.jpg (957.46 KiB) Viewed 130 times
- breakout_board.jpg (936.43 KiB) Viewed 130 times
- dastels
If the CPX is powering up then 5v & ground are good. Double check the D+ & D- connections. Wire color can be misleading so it's best to verify the connections with a meter.
