#include <Wire.h>
#include <SD.h>//sd card
#include <SPI.h>
#include <RTClib.h>// clock
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1017)// orig 1013.25 the local is 1017
//Global variable declaration
int co2_value_1;
int co2_value_2;
RTC_PCF8523 rtc;// clock on datalogger
Adafruit_BME280 bme; // I2C for T, RH, altitude, atm press
// create file
File myFile;
//String Date,Time,CO2_1,CO2_2;
String Date,Time,Temperature, Pressure, Altitude, Humidity, Data;
void setup() {//============================================================= SETUP===============
//start clock
//serial
Serial.begin(9600);
delay(2000);
//clock
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
Serial.flush();
while (1) delay(10);
if (! rtc.initialized() || rtc.lostPower()) {
Serial.println("RTC is NOT running, let's set the time!");
// When time needs to be set on a new device, or after a power loss, the
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
rtc.start();// added 4/4/2023 from pcf8523 code
//bme280 sensor
unsigned status;
status = bme.begin();
if (!status) {
Serial.println("BME280 not connected properly. Check circuit!");
while (1);
// SD card initialize
Serial.print("Initializing SD card...");
if (!SD.begin(10)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
myFile = SD.open("data.txt", FILE_WRITE);
if (myFile) {
myFile.println( "Date, Time, CO2_1(ppm), CO2_2(ppm),Temperature(°C), Pressure(hPa), Altitude(m), Humidity(%) \r\n");
myFile.close();
else {
Serial.println("error opening data.txt");
Wire.begin ();
pinMode(13, OUTPUT); // address of the Arduino LED indicator
Serial.println("Application Note AN-102: Interface Arduino to two K-333");
}//==================================================== close SETUP==========
//====================SUBROUTINES==================================
// Function : int readCO2_1()
// Returns : CO2 Value upon success, 0 upon checksum failure
// Assumes : - Wire library has been imported successfully.
// - LED is connected to IO pin 13
// - CO2 sensor address is defined in co2_addr
int readCO2_1()
{//+++++++++++++++++++++++++++++++++++++++++++++++++ read CO2()function definition
co2_value_1 = 0; // We will store the CO2 value inside this variable.
digitalWrite(13, HIGH); // turn on LED
// On most Arduino platforms this pin is used as an indicator light.
/* Begin Write Sequence */
Wire.beginTransmission(0x69);
// Wire.beginTransmission(co2Addr1);
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x08);
Wire.write(0x2A);
Wire.endTransmission();
/* End Write Sequence. */
We wait 10ms for the sensor to process our command.
The sensors's primary duties are to accurately
measure CO2 values. Waiting 10ms will ensure the
data is properly written to RAM
delay(10);
/* Begin Read Sequence */
Since we requested 2 bytes from the sensor we must
read in 4 bytes. This includes the payload, checksum,
and command status byte.
Wire.requestFrom(0x69, 4);
byte i = 0;
byte buffer[4] = {0, 0, 0, 0};
Wire.available() is not nessessary. Implementation is obscure but we leave
it in here for portability and to future proof our code
while (Wire.available())
buffer[i] = Wire.read();
i++;
/* End Read Sequence */
Using some bitwise manipulation we will shift our buffer
into an integer for general consumption
co2_value_1 = 0;
co2_value_1 |= buffer[1] & 0xFF;
co2_value_1 = co2_value_1 << 8;
co2_value_1 |= buffer[2] & 0xFF;
byte sum = 0; //Checksum Byte
sum = buffer[0] + buffer[1] + buffer[2]; //Byte addition utilizes overflow
if (sum == buffer[3])
// Success!
digitalWrite(13, LOW);
return co2_value_1;
else
// Failure!
Checksum failure can be due to a number of factors,
fuzzy electrons, sensor busy, etc.
return 0;
}//++++++++++++++++++++++++++++++++++++++++++ close the read CO2 function definition
// Function : int readCO2_2()
int readCO2_2()
co2_value_2 = 0; // We will store the CO2 value inside this variable.
Wire.beginTransmission(0x56);
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x08);
Wire.write(0x2A);
delay(10);
Wire.requestFrom(0x56, 4);
byte i = 0;
i++;
co2_value_2 = 0;
co2_value_2 |= buffer[1] & 0xFF;
co2_value_2 = co2_value_2 << 8;
co2_value_2 |= buffer[2] & 0xFF;
// Success!
return co2_value_2;
else
// Failure!
return 0;
//-------------------- data_logging() no values returned just save in sd card ----
void data_logging() {
String Temperature = String(bme.readTemperature(), 2);
String Pressure = String(bme.readPressure()/ 100.0F, 2);
String Altitude = String(bme.readAltitude(SEALEVELPRESSURE_HPA), 2);
String Humidity = String(bme.readHumidity(), 2);
Data = Temperature + "," + Pressure + "," + Altitude + "," + Humidity ;
Serial.print("Save data: ");
Serial.println(Data);
if (myFile) {
Serial.print("Writing to data.txt...");
//time stamp
DateTime now = rtc.now();
myFile.print(now.year(), DEC);
myFile.print('/');
myFile.print(now.month(), DEC);
myFile.print('/');
myFile.print(now.day(), DEC);
myFile.print(",");
myFile.print(now.hour(), DEC);
myFile.print(':');
myFile.print(now.minute(), DEC);
myFile.print(",");//delimeter between time and data
myFile.print(co2_value_1);
myFile.print(",");
myFile.print(co2_value_2);
myFile.print(",");
myFile.println(Data);//ln adds carriage return
myFile.close();
Serial.println("done.");
} else {
Serial.println();
//----------------------------------------------------End Subroutines-----------------------------------
void loop() {//##################################################### LOOP###############################
//once for sensor1 ADDRESS0x69//********
// int co2Value = readCO2();// orig
co2_value_1 = readCO2_1()*10;// what i was told to do. this gives half of what the dev kit prewired one reads.
if (co2_value_1 > 0)
Serial.print("CO2 Value1: ");
Serial.println(co2_value_1);
else
Serial.println("Checksum failed / Communication failure");
delay(1000);
//once for sensor2 ADDRESS0x56//********
// orig location of dataloging but if placed here then it would dataloge before it had values of Co2 moved it to end
co2_value_2 = readCO2_2()*10;// what i was told to do. this gives half of what the dev kit prewired one reads.
if (co2_value_2 > 0)
Serial.print("CO2 Value2: ");
Serial.println(co2_value_2);
else
delay(1000);
// make a string for assembling the data to log:
data_logging();
delay(300000);//time between writting to sd card: delay(ms) 1000=1sec ; 900,000=15 min use this for final use 300,000 (5 min) for testing
}//##############################################################################CLOSE LOOP#########################[attachment=0]output file.png[/attachment]
