STEMMA Qwiic cables
MonsterJoe
STEMMA Qwiic cables
Post by MonsterJoe »
I hope this is the right forum for this. To connect a bunch of your boards, I'd need to make my own cables.
However I can't find the right kit for that. Could you point me into the right direction?
I am talking, for example, about this: https://www.adafruit.com/product/5626. What would I need to make my own cables to connect to that?
Bonus: Also, I know i2c cables can only have a limited length (1-2m max). Does chaining them change any of that?
If this seems like a stupid question, it probably is. I am still new to all of this, so my google fu fails me. I did spend a few hours searching, but for somehow this topic still eludes me.
Re: STEMMA Qwiic cables
We do stock a selection of STEMMA cables: https://www.adafruit.com/product/4399
The connector used is a 4-pin JST SH.
https://www.jst-mfg.com/product/index.php?series=231
We do stock the jacks here: https://www.adafruit.com/product/4208
For the plugs, pins & crimping equipment, check with Mouser or DigiKey.
It doesn't matter if you chain them end-to-end or in a star configuration. The limiting factor is the total length of all the connected cabling. Things usually start getting dicey somewhere beyond a meter or so.
There is some capacitance between the parallel wires in the cable. The longer the cable, the larger the capacitance. Capacitance tends to round-off the edges of the signal pulses on the cable. Too much of it will start to interfere with proper communication.
MonsterJoe
Thanks a lot! I will look for JST SH.
I thought that maybe the signal would get re-emmitted or something like that. But I guess it's just one line going all the way through without any magic.
We do have an active terminator board that can help keep the signals in shape with longer runs: https://www.adafruit.com/product/4756
MonsterJoe
Thanks, going to grab a few of those as well then to try it out. Maybe lower clock rate already helps if there is an issue.
Yes, a lower clock rate can be helpful too. Obviously that limits the throughput as well. But not all applications require maximum speed.
