SEE SAW I2C Soil Sensor connectivity with Atmega 328P
- Lsowinski
Hello, I am attempting to utilize the see-saw I2C Soil Sensor with an Atmega 328p. I only need the capacitance value from the sensor, but on the website, the only address I can find is 0x36. I need to know what register the capacitance values are in so I can pull them independently from the temperature output.
- adafruit_support_carter
Re: SEE SAW I2C Soil Sensor connectivity with Atmega 328P
Is there a reason you can not use the Arduino library?
https://learn.adafruit.com/adafruit-ste ... duino-test
With that you can use getTemp() for temperature and touchRead(0) for the capacitance value.
If you really need low level register access, use:
SEESAW_TOUCH_BASE = 0x0F
SEESAW_TOUCH_CHANNEL_OFFSET = 0x10
Info on seesaw reading/writing here:
https://learn.adafruit.com/adafruit-see ... iting-data
- Lsowinski
I am attempting to utilize this for a school project where all of our coding is required to be done in c++ utilizing microchip studio.
Ok, then that guide is a good place to start for general info on seesaw register reading/writing.
For any info missing from the guide, the source code in that library linked is best source.
