Using SPI Flash with CircuitPython for Logging - itsybitsy M4
LuckyPenny
Post by LuckyPenny »
I have an application where I need to use the itsybitsy M4 SPI Flash (2MB) with CircuitPython to log and read data back.
I cannot find any circuitPython examples on how to initialize the SPI flash and use it to write to a file which receives a data log append to the file every hour. Then, periodically (weekly, monthly, or longer) read the data from the SPI Flash and forward it to a host server.
Is there anyway someone can provide me the circuitpython code to initialize, write to a file, and read the file back. The file can just have some text like "Hello-data log" and read it back.
I have searched all over for an example but can not find a reference to this type of data store. No need to access the data from the Arduino side - just circuitpython.
I am using the latest bootloader and circuitpython (8.x.x).
Thank you very much in advance.
Gary
dastels
Re: Using SPI Flash with CircuitPython for Logging - itsybitsy M4
Post by dastels »
You can create and write to a file on the flash filesystem without worrying about the details of the physical SPI flash. See https://learn.adafruit.com/circuitpytho ... on-storage.
LuckyPenny
Thank you for the quick response - Dave,
Does it automatically use the SPI Flash as an extension of the board flash?
Can I just read/write to the SPI Flash as a separate resource without worrying about access from the USB connected computer?
LuckyPenny
My desire is to use the SPI Flash as a separate and independent resource for logging and not use the internal flash of the device for storage. I have already used the link above to handle the mutual exclusion of only the CircuitPy using the storage OR the USB connected computer using the storage. I need to find out if the SPI Flash is really an independent resource like and SD card or other external storage.
Is this possible?
dastels
Post by dastels »
Unsure, but it is used as storage for the flash drive. I suspect you would need to make a custom build of CircuitPython that doesn't use the SPI flash as filesystem space.
Return to “Itsy Bitsy Boards”
