I have a Circuit Playground express that is staying red after pressing the reset button. So it won't turn green and none of my devices (both Mac and Windows) will not recognize the plugged in device. Is there a quick fix? Unfortunately we are passed the 30 day return policy since this was purchased in advance for a youth camp.
Neopixals staying red after pressing reset button
- kimwerezak
- adafruit_support_carter
Re: Neopixals staying red after pressing reset button
That is an indication of a USB issue. Most likely it's the USB cable. Double check the USB cable and make sure it is not charge only. Try using it with some other device and verify it can move data.
- kimwerezak
Thank you, I did try another cable and I'm getting the same result. Both cables work on another Circuit Playground express so it's not a cable issue.
- kimwerezak
I've tried another cable and another device. The Neopixels are staying red after pressing the reset. Could something be wrong with the usb port on the playground express?adafruit_support_carter wrote: ↑Mon Apr 10, 2023 1:44 pm That is an indication of a USB issue. Most likely it's the USB cable. Double check the USB cable and make sure it is not charge only. Try using it with some other device and verify it can move data.
Has this CPX ever worked before? Or is it new and acting like this?
- kimwerezak
This one no. We purchased it awhile ago as a part of a base kit through Digikey but this is the first time it's been opened and connected to a device. We ordered 40+ of the CPX and this is the first to have this problem.adafruit_support_carter wrote: ↑Mon Apr 10, 2023 2:58 pm Has this CPX ever worked before? Or is it new and acting like this?
- ericreed
I am having a similar issue. perhaps with some more specifics.
I have two students with Mac Apple silicon computers and bluefruit devices. They both connected their boards and tried to get Circuit Python installed. When they reset the board (before copying the uf2 file) all neopixels turn green for a moment and then red. The small red pixel (data?) continuously fast-flashes red.
If I bring the board and their usb cable and dongle to my computer, I can reset the board no problem, all neopixels stay green.
I don't have another fresh bluefruit board, but I brought a CPE to their computer and it worked fine. I observed that the mac asks two questions (I think unique to Apple silicon) about connecting a keyboard and accessing the device, as soon as the adafruit device is plugged in. I am wondering if somehow some bad configuration got attached to the bluefruit board that is preventing them from connecting to the mac.
I appreciate any help you can offer!
Eric
Eric
