QT Py SAMD21
- alainsam
QT Py SAMD21
Can the QT Py SAMD21 be used with the Arduino IDE?
- mikeysklar
Re: QT Py SAMD21
Yep, for sure. See linked guide.
- alainsam
Re: QT Py SAMD21
After installing the Adafruit SAMD, I selected the PY SAMD 21 I can compile but there is no port to select. Can you help?
PS: I also pressed the button on the board during compilation with no success.
- mikeysklar
Re: QT Py SAMD21
Are you using a known good USB cable? Does the QtPy get detected by your OS device manager when you plug it in?
You might need to manually select the port and double press the reset button to go into bootloader mode on the QtPy just before code upload.
- alainsam
Re: QT Py SAMD21
USB cable works with XIAO board, but the QtPy doesn't show any LED and doesn't seem to be detected by windows 10, it is powered as the Qt can power another board attached to it .
I double press the reset button several times without result and nothing shows on the device manager Ports.
- mikeysklar
Re: QT Py SAMD21
Okay, this Qt Py might have an issue. The hardware is probably working, but based on your description and lack of LED activity a bootloader might not be present. I recommend a replacement in this case.
Can you email [email protected] requesting a new unit. They will need your order# and a link to this forum thread as your authorization.
- alainsam
Re: QT Py SAMD21
Thanks for the offer but after many tests, it seems that I found the solution for my setting:
First I had to get more space on the computer by deleting some files and then when the
D://QTPY_BOOT file is created at the end of compilation, it shows on the display of the PC. This seems necessary to have the port working (COM 12 on my case) I do not know why but maybe you can explain it to me?
Anyway it works for now :=))
- mikeysklar
Re: QT Py SAMD21
Okay, I wouldn't have guessed a space issue, but they definitely can break everything when you are totally out of space to add file descriptors and what not.
