My two boards run the RX and TX examples just fine. Now I need to get them working with other devices that require a three byte address. The installed libraries do not provide addressing. Is there a library that provides for addressing?
I do not have code for the other devices.
Thanks.
Feather 32u4 RFM95 LoRa PID:3078
Re: Feather 32u4 RFM95 LoRa PID:3078
Taking a step back, can the RFM95 boards hear the other devices at all?
The radios don't support addresses at a low level, so the whole idea of address-based communication is kind of like using I2C: every device can hear every message, the code just ignores any messages that don't have the correct address for that device.
For the purposes of testing, a radio that reports everything it hears should be able to dump everything the three-byte-address devices are doing -if- the radio protocols are compatible at all.
- charlesl2
The other radios don't respond to messages from the Feathers, but the Feathers do see the messages from the others. The others only respond to messages sent with address 000000 or specific device address.
The feathers show the characters "ml" followed by the 3-byte address followed by the message in hex.
There are no TTN gateways in range.
- charlesl2
Addendum to my last post:
I wish to be able to send messages from the other radios to the Feathers and then get a response back from the Feathers.
