Hello everyone, I post here as my last hope of finding a solution after 3 days of non stop attempts/diagnostics.
I bought 6 RGB shields from Adafruit (mouser), in the hope of simplifying my project with a plug and play solution,
I have 2 p10 LED RGB 16x32 modules that I bought locally, and 3 arduino boards,
from all the library examples I only got one of them to work (I think so), which is testcolors, all the other ones either don't show anything on the LED (completely dead) or show some noise lines, or work in a pattern that I couldn't understand. I tried everything that I could but couldn't find the problem, I had the shields soldered at a repair shop, so the soldering is nicely done, the pins on the LED module are not labeled, but from my research I couldn't find any other pin layout that the one on your guide, Please suggest any steps in order to diagnose the issue. thanks
LED matrix shield not working
- kdz41
- IMG_20230413_133738.jpg (189.51 KiB) Viewed 198 times
- IMG_20230413_133804.jpg (114.91 KiB) Viewed 198 times
- IMG_20230413_133402.jpg (233.88 KiB) Viewed 198 times
- blnkjns
Re: LED matrix shield not working
What board do you use? Remember that RGB panels are not easy on the RAM usage.
I prefer using the protomatter library as it allows setting the bit depth, so you can go as low as 1 bit per colour, needing only 192 bytes for a single display or 384 byte buffered.
- kdz41
I got it to work by using a modified RGBmatrixPanel.cpp library that I found in a forum,
can you suggest an edit to the library in order to get it to work, as you can see it's supposed to display 16x32 *RGB*
but it's reversing the lines on the upper side and lower side of the display.
thanks
thanks
- IMG_20230414_160352.jpg (432.22 KiB) Viewed 187 times
- blnkjns
You still did not tell what board you use. Whether it works well depends on the pins you use. Some boards need pin rewiring. Wrong order problems usually indicate address line swaps.
- kdz41
Hi, I'm using an Arduino uno.
- kdz41
hello, it works now thanks to a modified library in the link below
the problem was that certain panels (outdoor ones) have a scan rate of 1/4
but the adafruit RGBpanel library was made to work with 1/8 scan rate panels
thanks for your help anyway bro
https://forum.arduino.cc/t/p10-rgb-outd ... no/1115227
