// using ATTinycore (which supports Wire.h)
// Board: ATTiny/25/45/85(no bootloader)
// Programmer: Arduino as ISP
// ATTiny85 running at 16MHz(PLL) and burned bootloader
#define Tiny 1 // if defined compile for ATTiny85 io. Arduino
#define Use_TinyWire 1 // if defined uses TiniWireM.h io. Wire.h
#ifdef Use_TinyWire
#include <TinyWireM.h> // I2C Master lib for ATTinys which use USI
//#include <USI_TWI_Master.h>
#else
#include <Wire.h>
#endif
#ifdef Tiny
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#define LED_PIN 3 // PB3 pin to which the NeoPixels are attached
#else
#define LED_PIN 6 // pin to which the NeoPixels are attached
#endif
#define LED_COUNT 8 // number of pixels attached to NEO pixelstrip
#include "Adafruit_TCS34725.h"
Adafruit_NeoPixel strip (LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS, TCS34725_GAIN_4X);//https://learn.adafruit.com/adafruit-color-sensors/library-reference
int minr,ming,minb,maxr,maxg,maxb;
int myred,mygre,myblu;
#ifndef Tiny
Serial.begin (115200);
while (!Serial);
Serial.println ("Color View Test!");
#endif
strip.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
strip.show(); // Turn OFF all pixels ASAP
strip.setBrightness(5); // Set BRIGHTNESS to about 1/5 (max = 255)
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
// USI_TWI_Master::init();
// TinyWireM::USI_TWI_Master twi;
#ifndef Use_TinyWire
// Wire.setClock(100000); // set I2C clock speed to 100kHz
Wire.setClock(10000); // set I2C clock speed to 100kHz
#endif // TinyWireM.setClock() doesnot exist
setcolor(0,255,0); // green: processor is running at 16mhz
#else
setcolor(255,0,0); // red: processor is not running at 16mhz or not ATTiny
#endif
delay(1000);
displayAddresses(); // scan i2c bus for devices and diplay found address binairy on 8 pixel ledstrip
if (tcs.begin()) {
#ifndef Tiny
Serial.println ("Found sensor");
#else
setcolor (0,0,255);//blue: show blue leds found sensor
#endif
} else {
#ifndef Tiny
Serial.println ("No TCS34725 found ... check your connections");
#else
setcolor (255,0,255);//violet: no sensor found
#endif
while (1); // halt!
setcolor(0,255,0); //green: show everything is OK
delay (1000);
minr=255;
ming=minr;
minb=minr;
float red, green, blue;
delay(60); // takes 50ms to read
tcs.getRGB (&red, &green, &blue);
if (red>maxr) {maxr=red;}
if (red<minr) {minr=red;}
if (green>maxg){maxg=green;}
if (green<ming){ming=green;}
if (blue>maxb) {maxb=blue;}
if (blue<minb) {minb=blue;}
myred=map(int(red), minr,maxr,0,255);
mygre=map(int(green),ming,maxg,0,255);
myblu=map(int(blue), minb,maxb,0,255);
#ifndef Tiny
Serial.print("R:"); Serial.print(String(int(red)) +"("+String(minr)+"-"+String(maxr)+")");
Serial.print("\tG:"); Serial.print(String(int(green))+"("+String(ming)+"-"+String(maxg)+")");
Serial.print("\tB:"); Serial.print(String(int(blue)) +"("+String(minb)+"-"+String(maxb)+")");
Serial.print("\t");
Serial.print((int)red, HEX); Serial.print((int)green, HEX); Serial.print((int)blue, HEX);
Serial.print("\t");
Serial.print(String(myred)+"/"+String(mygre)+"/"+String(myblu));
Serial.print("\n");
#endif
setcolor (myred,mygre,myblu);
delay (100);
void setcolor(int r,int g,int b){
strip.clear ();
for (int n=0;n<LED_COUNT;n++){
strip.setPixelColor(n, strip.Color(r,g,b));
strip.show();
delay (250);
void displayAddresses() {
int nDevices = 0;
#ifndef Tiny
Serial.println("Scanning...");
#endif
#ifdef Use_TinyWire
//const uint32_t TWI_SPEED = 100000UL; // desired clock speed
//TinyWireM.begin(TWI_SPEED); // set I2C clock frequency to 100 kHz does not work
TinyWireM.begin();
#else
Wire.begin();
#endif
for (byte address = 1; address < 127; ++address) {
byte saveA=address;
byte binaryAddress[8]="00000000";
byte index = 0;
// Converteer het I2C-adres naar binaire notatie
while (saveA > 0) {
binaryAddress[index++] = saveA % 2;
saveA /= 2;
strip.clear ();
// Schrijf het binaire adres naar de ledstrip
for (int i = 0; i < 8; i++) {
if (binaryAddress[i] == 1) {
strip.setPixelColor(i, 255);
} else {
strip.setPixelColor(i, 0);
strip.show();
#ifndef Tiny
Serial.println(address);
#endif
TinyWireM.beginTransmission(address);
byte error = TinyWireM.endTransmission();
#else
Wire.beginTransmission(address);
byte error = Wire.endTransmission();
#endif
if (error == 0) {
#ifndef Tiny
Serial.print("I2C device found at address 0x");
if (address < 16) {
Serial.print("0");
Serial.print (address, HEX);
Serial.print ("HEX ");
Serial.print (address, BIN);
Serial.println("BIN");
#endif
++nDevices;
delay(5000);
} else if (error == 4) {
#ifndef Tiny
Serial.print("Unknown error at address 0x");
if (address < 16) {
Serial.print("0");
Serial.println(address, HEX);
#else
setcolor(255,255,0);//REDGREEN
delay (5000);
#endif
delay(50);
if (nDevices == 0) {
#ifndef Tiny
Serial.println("No I2C devices found\n");
#else
setcolor(0,255,255);//BLUEGREEN
delay (5000);
#endif
