Seriel1 not declared basic uart_rvc
Oeuf
Post by Oeuf »
Hey, new member here, I recently tried out the UART-RVC setup on the Arduino UNO shell, and when I tried to run it gave me this error message:
C:\Users\User\BANNED\Documents\Arduino\uart_rvc\uart_rvc.ino: In function 'void setup()':
uart_rvc:17:3: error: 'Serial1' was not declared in this scope
   Serial1.begin(115200); // This is the baud rate specified by the datasheet
C:\Users\User\BANNED\Documents\Arduino\uart_rvc\uart_rvc.ino:17:3: note: suggested alternative: 'Serial'
   Serial
exit status 1
The code is :
#include <Adafruit_BNO08x_RVC.h>
/* Test sketch for Adafruit BNO08x sensor in UART-RVC mode */
Adafruit_BNO08x_RVC rvc = Adafruit_BNO08x_RVC();
  // Wait for serial monitor to open
  Serial.begin(115200);
  while (!Serial)
    delay(1);
  Serial.println("Adafruit BNO08x IMU - UART-RVC mode");
  while (!Serial1)
    delay(10);
  if (!rvc.begin(&Serial1)) { // connect to the sensor over hardware serial
    Serial1.println("Could not find BNO08x!");
    while (1)
      delay(10);
  Serial.println("BNO08x found!");
  BNO08x_RVC_Data heading;
  if (!rvc.read(&heading)) {
    return;
  Serial.println();
  Serial.println(F("---------------------------------------"));
  Serial.println(F("Principal Axes:"));
  Serial.print(F("Yaw: "));
  Serial.print(heading.yaw);
  Serial.print(F("\tPitch: "));
  Serial.print(heading.pitch);
  Serial.print(F("\tRoll: "));
  Serial.println(heading.roll);
  Serial.println(F("Acceleration"));
  Serial.print(F("X: "));
  Serial.print(heading.x_accel);
  Serial.print(F("\tY: "));
  Serial.print(heading.y_accel);
  Serial.print(F("\tZ: "));
  Serial.println(heading.z_accel);
  //  delay(200);
The website source:
https://learn.adafruit.com/adafruit-9-d ... or-arduino
Does it mean that: The UNO shell is incapable? Or there is something missing in the code?
adafruit_support_carter
Re: Seriel1 not declared basic uart_rvc
For the UNO, will need to use SoftwareSerial.
https://docs.arduino.cc/learn/built-in- ... are-serial
Try this wiring:
  • UNO 5V to BNO VIN
  • UNO GND to BNO GND
  • UNO #2 to BNO SDA
  • BNO P0 to BNO 3Vo (this sets RVC mode)
And this sketch:
#include <SoftwareSerial.h>
#include "Adafruit_BNO08x_RVC.h"
const byte rxPin = 2;
const byte txPin = 3;
// Set up a new SoftwareSerial object
SoftwareSerial mySerial (rxPin, txPin);
  while (!Serial)
    delay(10);
  mySerial.begin(115200); // This is the baud rate specified by the datasheet
  if (!rvc.begin(&mySerial)) {
    Serial.println("Could not find BNO08x!");
    while (1)
      delay(10);
    return;
  Serial.println();
  //  delay(200);
gammaburst
Post by gammaburst »
That SoftwareSerial sketch will kinda run on an Uno, but you'll probably see some data glitches and less than the full 100 readings per second.
The Uno has has only one hardware UART, and it's connected to the USB interface.
You'll have better luck using a different processor that has an extra hardware UART.
