Gemma M0 won't power up
- rdock1186
I just received a Gemma M0. It does not power up. I’ve tried five different cables on two different PCs and get no LEDs or any other indication that the product is working. I’ve verified the power switch was in the “on” position.
- adafruit_support_carter
Re: Gemma M0 won't power up
You may need to upload a program first before you see anything on the onboard LEDs. Have you tried programming it yet?
https://learn.adafruit.com/adafruit-gemma-m0
As another quick test, try double pressing the reset button and see if you can get the GEMMABOOT folder to show up.
Also super double triple check the USB cables. Try using them with something else and verify they can move data.
- rdock1186
It doesn't power up. It doesn't enumerate on any PC. It's impossible to run a program on it if it doesn't power up. I need a replacement.
OK, yah, sounds like something just isn't right. Let's replace it.
Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement GEMMA M0.
