i'm in need of some Help. i wanted to build the cauldron from this project for my LARP Alchemist.
https://learn.adafruit.com/cpx-cauldron/software
i habe three of the blue fruit Boards ans two Basic, as i first order the wrong typ.
i followed the guide and got the boars to run, but i cant get a stable connection. i can from time to time connect my mobil to the board an chance the leds but its not stable an i will get send back to the overview with als Bluetooth devices in reach and cant connect again. (mobil is a Google Pixel 4)
also i would more like a stand alone version that give light with out BLuetooth. so i found this one via Youtube
https://github.com/Nrico/Circuit-Playground
change the code in the Code.py with that from the line above and added the "Adafruit_CircuitPlayground" in the Lib folder but nothing change on the board. the board with the "new" code just light up all LEDs in white.
do i miss anything for the flickering?
and what can cause the BT issues?
thank you for any advice
BR Martin
Need Help with Playground - Bluetooth and Flickering LEDs
- Flotsch
- mikeysklar
Re: Need Help with Playground - Bluetooth and Flickering LEDs
The example code you found is Arduino based so you would have to use the Arduino IDE to upload it to CircuitPlayground. It is not python code so creating a code.py will not work.
The project requires Android 4.4 or later which I assume you are running on your Pixel 4. BLE is great for quick setting changes, but it will disconnect when you get too far away or timeout.
- Flotsch
thank you so much!
i realy got lost in the too many guides an different tools to use:)
it works
it works
