Adafruit Feather and Adafruit Ultimate GPS
Chaz10297
Post by Chaz10297 »
Hello, I am currently working with the GPS breakout board and ESP32-s3 feather. I am having issues retrieving a date from the GPS unit. I am getting a fix and an accurate GPS location though. When I call GPS.day .month .year all I get is zeros. Any suggestions?
#include <Adafruit_GPS.h>
#define GPSSerial Serial1 //Hardware serial port
#include <LiquidCrystal_I2C.h>
Adafruit_GPS GPS(&GPSSerial); //Connect to GPS unit
//initalise time and date verables
  int hour;
  int minute;
  byte day;
  byte month;
  byte year;
// set the LCD number of columns and rows
int lcdColumns = 16;
int lcdRows = 2;
// set LCD address, number of columns and rows
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
#define GPSECHO false
uint32_t timer = millis();
//print out the current GPS location
void print_GPS(){
  lcd.clear();//Clear display
  lcd.setCursor(0,0);//set cursor to position 0, line 0
  lcd.print("GPS:");//print GPS
  lcd.setCursor(5,0);//Move cursor
  lcd.print(GPS.latitude);//print Latitude
  lcd.setCursor(12,0);//move cursor
  lcd.print(GPS.lat);//print north or south
  lcd.setCursor(5, 1);//move cursor
  lcd.print(GPS.longitude);//print longitude
  lcd.setCursor(12, 1);//move cursor
  lcd.print(GPS.lon);//print east or west
  delay(5000);//keep location displayed for 5 seconds
  lcd.clear();//clear display
//print the last detection time and date
void print_date(){
    lcd.print("Date: ");// print DATE:
    lcd.setCursor(6, 0);//move cursor
    lcd.print(month);//print month in 00 format
    lcd.setCursor(8, 0);//move cursor
    lcd.print("/");//print /
    lcd.setCursor(9, 0);//move cursor
    lcd.print(day);//print day in 00 format
    lcd.setCursor(11, 0);//move cursor
    lcd.setCursor(12, 0);//move cursor
    lcd.print(year);//print year in 0000 format
    lcd.setCursor(0, 1);//move cursor
    lcd.print("Time:");//print Time:
    lcd.setCursor(6, 1);//move cursor
    lcd.print(hour);//print hour
    lcd.setCursor(8, 1);//move cursor
    lcd.print(":");//print :
    lcd.setCursor(9, 1);//move cursor
    lcd.print(minute);//print minute
//setup code
  Serial.begin(9600);//
  pinMode(A4, INPUT_PULLDOWN);         // RF ADC
  pinMode(A1, INPUT_PULLDOWN);         //Light Detector Input
  pinMode(A2, INPUT_PULLDOWN);         //Trigger for GPS Location
  pinMode(13, OUTPUT);//All Clear LED (Green)
  pinMode(12, OUTPUT);//RF detection LED (Yellow)
  pinMode(11, OUTPUT);//Lightning flash detection LED(Blue)
  pinMode(10, OUTPUT);//Detection confermed LED(Red)
  GPS.begin(9600);//// 9600 NMEA is the default baud rate for Adafruit MTK GPS
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);// turn on only the "minimum recommended" data
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
  GPS.sendCommand(PGCMD_ANTENNA);// Request updates on antenna status
  // initialize LCD
  lcd.init();
  // turn on LCD backlight
  lcd.backlight();
  //Print Boot Message
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Lightning");
  lcd.setCursor(0,1);
  lcd.print("Detection");
  delay(2000);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("System");
  delay(2000);
  lcd.clear();
  delay(1000);//keep message displayed
  // put your main code here, to run repeatedly:
  int x = analogRead(A4);//ADC for RF detection
  double v = (x*3.3)/4095;//Voltage at ADC conversion
  bool b = digitalRead(A1);//read pin 15 for light detection
  double vThres = 1.0; //V theshold for RF Detector
  //manual trigger read GPS location
  if (digitalRead(A2)){
    char c = GPS.read();//read data frin GPS main loop
    if (GPSECHO){
      if (c) Serial.print(c);
    if (GPS.newNMEAreceived()) // print the NMEA sentence, or data, cannot listen and catching new sentences
      Serial.print(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
      if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
        return; // we can fail to parse a sentence in which case we should just wait for another
      //Print GPS location data to lcd
    if (GPS.fix) {
      Serial.print("Location: ");
      Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
      Serial.print(", ");
      Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
      Serial.print("Speed (knots): "); Serial.println(GPS.speed);
      Serial.print("Angle: "); Serial.println(GPS.angle);
      Serial.print("Altitude: "); Serial.println(GPS.altitude);
      Serial.print("Satellites: "); Serial.println((int)GPS.satellites);
      Serial.print("Antenna status: "); Serial.println((int)GPS.antenna);
      print_GPS();
      print_date();//Reprint last confermed detection
      Serial.println(GPS.milliseconds);
      Serial.print("Date: ");
    Serial.print(GPS.day, DEC); Serial.print('/');
    Serial.print(GPS.month, DEC); Serial.print("/20");
    Serial.println(GPS.year, DEC);
    Serial.print("Fix: "); Serial.print((int)GPS.fix);
    Serial.print(" quality: "); Serial.println((int)GPS.fixquality);
  //LED and detection logic
  if (v > vThres && digitalRead(A1) == HIGH){//RF detected but no flash
    digitalWrite(13, LOW);//Turn off Green LED
    digitalWrite(12, HIGH);//Turn on Yellow LED
    Serial.println("RF Detection. Possible Lightning in the Area");
    //lcd display message
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("RF DETECTION IN");
    lcd.setCursor(0,1);
    lcd.print("AREA.");
    delay(3000);
    print_GPS();
    digitalWrite(12, LOW);//Turn off RF detection LED (Yellow)
    digitalWrite(13, HIGH);//All clear LED (Green)
    lcd.clear();
  if (digitalRead(A1) == LOW && v < vThres){//Flash but no RF
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Flash DETECTION");
    digitalWrite(11, HIGH);//Turn on flash detection LED (Blue)
    Serial.println("Flash Detection");
    delay(3000);//Delay to reduce detecting the same signal more than once
    print_GPS();
    digitalWrite(11, LOW);//FLash detection LED (Blue)
    lcd.clear();
  if (v > vThres && digitalRead(A1) == LOW){//Both flash and RF detected
    minute = GPS.minute;
    hour = GPS.hour-4;
    day = GPS.day;
    month = GPS.month;
    year = GPS.year;
    digitalWrite(10, HIGH);//Turn on lightning confermed LED (Red)
    Serial.println("Lighting is in the Area, Seek Shelter!");
    print_GPS();
    digitalWrite(10, LOW);//Turn off lightning confermed LED (Red)
    print_date();
adafruit_support_carter
Re: Adafruit Feather and Adafruit Ultimate GPS
Is that based on output in the Serial Monitor, or output on the LCD from print_date()?
Return to “Other Arduino products from Adafruit”
