MQTT example crashes when trying to get a feed
nocom
Post by nocom »
I try to setup my Raspberry Pico W so that it will pass measurements to adafruit.io by trying to replicate the example found on https://learn.adafruit.com/pico-w-wifi- ... dafruit-io. I adapted the code somewhat and the main portion is:
wifi.radio.connect(os.getenv('WIFI_SSID'), os.getenv('WIFI_PASSWORD'))
#  prints IP address to REPL
print("IP address is", wifi.radio.ipv4_address)
aio_username = os.getenv('aio_username')
aio_key = os.getenv('aio_key')
pool = socketpool.SocketPool(wifi.radio)
requests = adafruit_requests.Session(pool, ssl.create_default_context())
# Initialize an Adafruit IO HTTP API object
io = IO_HTTP(aio_username, aio_key, requests)
print("connected to io:", io)
# get feed
picowHumid_feed = io.get_feed("distance")
That all works fine until the last line, i get:
>>> %Run -c $EDITOR_CONTENT
IP address is 192.168.178.58
connected to io: <IO_HTTP object at 0x20017250>
  File "<stdin>", line 58, in <module>
  File "adafruit_io/adafruit_io.py", line 707, in get_feed
  File "adafruit_io/adafruit_io.py", line 555, in _get
  File "adafruit_requests.py", line 730, in get
  File "adafruit_requests.py", line 673, in request
  File "adafruit_requests.py", line 600, in _send_request
AttributeError: 'NoneType' object has no attribute 'encode'
As can be seen from the output is that variable io has a value, so is not None. The error occurs in the requests library where the encoding value is None. Any idea what is the cause of this?
barshatriplee
Re: MQTT example crashes when trying to get a feed
Post by barshatriplee »
The error message 'NoneType' object has no attribute 'encode' suggests that the requests library is trying to encode a None value. One possible cause of this error is that the io.get_feed() method is returning None instead of a valid response.Verify that the io.get_feed() method is returning a valid response by printing the response before trying to use it.
